fly boy3 Posted October 18, 2019 Share Posted October 18, 2019 Just a thought. I need to replace an Xc with another of a different make. 35Mhz. Can I be sure all servos will move in same direction as with the original reciever. Is the signal to the servo just a voltage ? Thanks Quote Link to comment Share on other sites More sharing options...
Geoff S Posted October 18, 2019 Share Posted October 18, 2019 The receiver is just a conduit from the transmitter to the servos. All other things being equal, changing it won't affect anything else. However check before you fly and certainly check if you change a servo, they can definitely travel in a different direction. Geoff Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted October 19, 2019 Author Share Posted October 19, 2019 Thanks for the info. Geoff, I thought as much. As an extra question, does the Xc just put a voltage on the servo, or is the signal a bit more complicated ? Cheers Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted October 19, 2019 Share Posted October 19, 2019 FB the answer is that it's not just a voltage no. It's a regular series of electrical pulses. The duration of the pulse tells the servo which position to go to. For most systems, if the pulses keep coming, each having a duration of 1.5uS then the servo will be centred. If the pulses move towards 1uS long then the servo will go one way and if they move towards 2uS then the servo will go the other way. Assuming that you're using the same 35mHz transmitter then it's the Tx that sets the pulse lengths, so the servo should go the same way even if you change Rx. I guess there's a possibility that a Rx with digital signal processing might change the direction, but even then I'd doubt it. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted October 19, 2019 Share Posted October 19, 2019 I don't know what your experience is in RC, but just to add to CB's response above, the Rx (receiver) does send a constant voltage to the servo via its red and black wires in the 3-wire connecting cable. This provides power for the servo motor and the little electronics bits inside the servo that decode the signal and tell its motor what to do. The signal itself is transmitted to the servo via the third, white or yellow, wire in the 3-wire cable, and is as explained by CB. Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted October 20, 2019 Author Share Posted October 20, 2019 Thanks Chris and Allan for the info,quite interesting indeed. Hi Allan, I have very many years of flying in rc Sometimes I get a thought in my mind,and Ineed an explanation if possible lol. Thanks. Quote Link to comment Share on other sites More sharing options...
