Tim Donald Posted November 8, 2019 Share Posted November 8, 2019 Will Ripmax SD100 servos work directly from a 1S Lipo or will they loose too much torque? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted November 8, 2019 Share Posted November 8, 2019 You can see the SD100s are 4.8v Tim But there are other micro servos, to suit you, From Micron HK 2.2gm Micro Servo Specification, Size (LxWxH): 16 x 8 x 20 mm Weight: 2.5 gm Torque: 0.2 kg/cm @ 3.7V Speed: 0.08 sec/60° @ 3.7V Edited By Denis Watkins on 08/11/2019 19:33:26 Quote Link to comment Share on other sites More sharing options...
Tim Donald Posted November 8, 2019 Author Share Posted November 8, 2019 Thanks, I ask because the spec is 4.0v to 8.4v so wondered if 3.7 would still work. I have them already but no 1S to test. Bought them to run from 2S but a 1S would fit the model better. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted November 8, 2019 Share Posted November 8, 2019 1S would struggle, and could pull your Rx to failsafe Your answer is small 2S Lipos Underpowering is really problematic on any part of the model Edited By Denis Watkins on 08/11/2019 20:30:44 Quote Link to comment Share on other sites More sharing options...
Tim Donald Posted November 8, 2019 Author Share Posted November 8, 2019 OK thanks Denis, 2S it is. Was worth asking Quote Link to comment Share on other sites More sharing options...
