Tim Donald Posted April 1, 2020 Share Posted April 1, 2020 I see that the latest Max Thrust Riot v2 can use a 14.8v lipo for extra performance over the standard 11.1v. Does anyone know if I can do this on a WOT-4 Foam-E too? Quote Link to comment Share on other sites More sharing options...
FlyinBrian Posted April 1, 2020 Share Posted April 1, 2020 See what is the largest size piece of foam or balsa you can fit in then check out the sizes of the various Lipos at HK etc. Don't forget to check the current draw if you fit a 4 cell pack Quote Link to comment Share on other sites More sharing options...
Tim Donald Posted April 2, 2020 Author Share Posted April 2, 2020 Hi Brian, thanks it's not so much the size but would a 14.8v burn up the motor or ESC ? Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 2, 2020 Share Posted April 2, 2020 hello tim,cant be certain,but you need to check out the speck of the motor and esc fitted...should be in the instruction sheet or on the parts themselves.....maybe they are only fit for a 3s set up and as has been said...if you go 4s,you may fry your gear.. result new model reqd.. ken anderson...ne..1...frying dept. Quote Link to comment Share on other sites More sharing options...
