Gary Murphy 1 Posted April 15, 2020 Share Posted April 15, 2020 I have just seen a range of servo`s made my SPL. The quality looks good for the price. The thing is these servo`s have applications for ,robotics/car/plane/heli. Some have a rotation of 360,270,180 and 90. some that quote car/plane/heli have 180deg as well as 90deg. Do I need to stick with the 90 deg version? for plane/car OR 180 deg? There is a particular thing I see in a product vid,when the servo is not under power the arm can be turned constantly and doe not hit a full position.every servo I have had hits a lock????? In the servo tech sheet "lock on/off" is listed. Does any of this make sense? Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted April 15, 2020 Share Posted April 15, 2020 I often use TGY 180D MG ones on flaps because the servo is then under zero load with flaps up or down. I cannot think why you would want to use similar on other control surfaces of an aircraft. Quote Link to comment Share on other sites More sharing options...
Bruce Miller 2 Posted April 17, 2020 Share Posted April 17, 2020 Posted by Gary Murphy 1 on 15/04/2020 21:53:11:There is a particular thing I see in a product vid,when the servo is not under power the arm can be turned constantly and doe not hit a full position.every servo I have had hits a lock????? In the servo tech sheet "lock on/off" is listed. Does any of this make sense? One use that I know of for a non-stop (lock OFF?) servo is for a model sailboat winch. The end-points are set in transmitter. I imagine robotics might have similar use? Quote Link to comment Share on other sites More sharing options...
