Denis Watkins Posted May 25, 2020 Share Posted May 25, 2020 Do it again holding the Tx 6ft away With you inbetween the Tx and Rx Quote Link to comment Share on other sites More sharing options...
Tony Fox 1 Posted May 25, 2020 Author Share Posted May 25, 2020 Ok done all that. Tried standing about 3 meters away still nothing. Just getting a flashing light on trans the two bleeps. Take bind plug out and plug battery back into bind port. Still nothing. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted May 25, 2020 Share Posted May 25, 2020 Tony You can't bind an rx trying different ways Only one sequence works Tx OFF Power the Rx to produce a rapid flashing LED, having the bind plug in the Bind And the power elsewhere in the rx Holding the bind button, with the throttle stick down/Off Switch on the Tx Job done or sequence not followed or equipment fault Quote Link to comment Share on other sites More sharing options...
Tony Fox 1 Posted May 30, 2020 Author Share Posted May 30, 2020 Hi all. Sorted now thanks to darbro models. I was doing the process correctly. Faulty reciver. Thanks Tony. Quote Link to comment Share on other sites More sharing options...
