sas wild thing
The best AA battery to get is an Eneloop 2000mAH, this one for instance. Don't be tempted to get any AA that has higher capacity.
The Rx & servos are not critical, any 2 or more channel Rx that will fit & Futaba 3003's should be fine. The model will probably still need some nose weight for balance but it's not a model that needs to be as light as possible.
