Peter Miller Posted January 6, 2021 Share Posted January 6, 2021 Just a silly little idea. We should always remove props on electric models when working on the bench and powering up the system. How do I know!! When fitting one of those spinners which are held on with two screws I always have to fit them, then slacken them and adjust a few times. I was just taking a prop off a model and thinking about refitting it when I realised a very simple idea would save a lot of fiddling. Before slacking off the prop nut I marked the prop with a ball point pen with the marks aligned to the screw holes. Now I just have to line them up tighten the prop nut and fit the spinner screws first time. Of course if you have to fit a new prop then you have to mark that one. Edited By Peter Miller on 06/01/2021 14:33:30 Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted January 6, 2021 Share Posted January 6, 2021 I always mark the back plate of spinner with lines each side of prop Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 6, 2021 Author Share Posted January 6, 2021 That sounds an even better idea Quote Link to comment Share on other sites More sharing options...
Andy48 Posted January 6, 2021 Share Posted January 6, 2021 Posted by Keith Berriman on 06/01/2021 16:35:38: I always mark the back plate of spinner with lines each side of prop I do the same with a permanent fibre tip pen. Quote Link to comment Share on other sites More sharing options...
