David Davis Posted April 28 Author Share Posted April 28 (edited) I turned the model the right way up and got this result. Neither the rudder nor elevator servo has been installed yet neither has the rx battery but putting the pilot into the cockpit, even in the most advanced position, causes the model to tip over. Some cosmetic work to do too. Edited April 28 by David Davis Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted April 29 Share Posted April 29 Looking good. One thing you might want to do is reverse the forward sweep of the undercarriage by simply turning it round. This is because by using the more modern fixing of the aluminium undercarriage, it puts the wheels further forward than the kit wire version. That means there is lots of tail wheel weight which spoils ground handling. Quote Link to comment Share on other sites More sharing options...
David Davis Posted April 29 Author Share Posted April 29 Thank you for that suggestion Tim, I'll try it out. 1 Quote Link to comment Share on other sites More sharing options...
