Martin McIntosh Posted May 30, 2021 Share Posted May 30, 2021 Here is yet another, my new DB 57" Tiggy. Laser 70 for grunt and at 6 1/4 lbs flies quite well. I need a larger diameter and lower pitch prop than the current 13x6 to tame it down a little. Built from scratch from the Sarik plan. 3 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted May 30, 2021 Share Posted May 30, 2021 That's rather nice. Did you use the sarik cowl? Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted May 31, 2021 Author Share Posted May 31, 2021 Yes I did Nigel. One reason for building it that size was because I thought it would save me from moulding one. Don`t know which model it was for but certainly not the 57". A mate is also doing one which was started by his father many years ago and he is having the same problems. I had to remove at least 10mm from the firewall (F2) to squeeze it in place and it only just goes on far enough. It is incredibly thick, about four times thicker than those I make. Quote Link to comment Share on other sites More sharing options...
