Svenson 1/6 Storch Kit
Andy J
Acquired some years ago a highly detailed  Svenson 1/6th scale Storch kit minus its ailerons and flaps. Now in the process of building the missing parts using a design taken from a 1/4 scale plan (appropriately scaled) but stuck as to how the hinge mechanism allows an upward movement of the aileron. This is because the hinge point is placed under and rearward of the aileron LE  so when the aileron moves up its LE moves down and fowls the hinge arm strut protruding from the wing.
Found the attached graphic on line which I think answers my problem as can see that the leading edge of the aileron appears to have slots cut forward of the hinge. So does anyone still have a Svenson kit and can confirm the ailerons do indeed have slots cut into the leading edge of the ailerons to avoid fowling the hinge arm?
