'Widget' Posted November 30, 2008 Share Posted November 30, 2008 Hi, Has anyone been able to assess the new Specktrum AR500 DSM2 full range R/X yet & if so could you let me know the plus & minus points please. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 30, 2008 Share Posted November 30, 2008 + = full range, ( flown mine in a large model WAY out and away ) DSM2, decent compact size and decent price- = no end pin variant. Quote Link to comment Share on other sites More sharing options...
'Widget' Posted December 1, 2008 Author Share Posted December 1, 2008 Thanks Timbo, Nice to know, I was slightly concerned about the AR500 as my other Spektrum R/X's have the remote R/X attached. Any special way the aeriel leads should be positioned on the AR500 ? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 1, 2008 Share Posted December 1, 2008 Yes as this is actually two receivers also ...but fitted in one case similar to the older AR6000 - ideally the longer aerial should be taken away from the case, and the tip of it ( which is the actual antenna) should be placed at right angles to the other short one which simply protudes from the case. Quote Link to comment Share on other sites More sharing options...
stuey Posted December 1, 2008 Share Posted December 1, 2008 Check how long it takes to respond after a quick power loss, should come back almost instantly. My two took 3 to 4 seconds to come back to life, had them upgraded by Horizon. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 1, 2008 Share Posted December 1, 2008 stuey wrote (see)Check how long it takes to respond after a quick power loss, should come back almost instantly. My two took 3 to 4 seconds to come back to life, had them upgraded by Horizon.yes thats a fair point - mine is also slower to reboot after a brown out than all my other spekky receivers ( 15 in all ) Quote Link to comment Share on other sites More sharing options...
iawnski Posted December 2, 2008 Share Posted December 2, 2008 is it best to have the aerial in/out the fuz on my graupner elecy,as im just waiting to test fly her with the 2.4 spekky weather permiting Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 2, 2008 Share Posted December 2, 2008 if its only in foam, then inside is fine.I have emailed you by the way Quote Link to comment Share on other sites More sharing options...
iawnski Posted December 2, 2008 Share Posted December 2, 2008 replied Quote Link to comment Share on other sites More sharing options...
