Formtex1947 Posted October 27, 2022 Share Posted October 27, 2022 Would anyone who has a Peter Miller plan for the Feugray TR-260 please contact me with a view to selling it or allowing me to copy said plan. Many thanks. Richard Whitwick Leices. Quote Link to comment Share on other sites More sharing options...
Caveman Posted October 27, 2022 Share Posted October 27, 2022 (edited) Richard, In your previous topic where you were asking what model it was Peter Miller attached a pdf copy of the plan. Copy the pdf onto a memory stick and take it to a local print shop and they can print it out at full size. They could also adjust the scale if you needed a smaller or larger model. Alternatively you can use Acrobat to print it onto several sheets of A4 paper which can be assembled into a full plan. Having said that when I’ve gone down this route I only print the parts needed. GDB Edited October 27, 2022 by Caveman Quote Link to comment Share on other sites More sharing options...
Formtex1947 Posted October 28, 2022 Author Share Posted October 28, 2022 23 hours ago, Caveman said: Richard, In your previous topic where you were asking what model it was Peter Miller attached a pdf copy of the plan. Copy the pdf onto a memory stick and take it to a local print shop and they can print it out at full size. They could also adjust the scale if you needed a smaller or larger model. Alternatively you can use Acrobat to print it onto several sheets of A4 paper which can be assembled into a full plan. Having said that when I’ve gone down this route I only print the parts needed. GDB 23 hours ago, Caveman said: Richard, In your previous topic where you were asking what model it was Peter Miller attached a pdf copy of the plan. Copy the pdf onto a memory stick and take it to a local print shop and they can print it out at full size. They could also adjust the scale if you needed a smaller or larger model. Alternatively you can use Acrobat to print it onto several sheets of A4 paper which can be assembled into a full plan. Having said that when I’ve gone down this route I only print the parts needed. GDB Quote Link to comment Share on other sites More sharing options...
