Nigel Heather Posted January 18, 2023 Share Posted January 18, 2023 For a given motor, ESC, propellor and battery is it possible to easily calculate the thrust. I’m talking about predicted values here, I don’t physically have the parts, they are still on the store shelves, so can’t do any actual calculations, just theoretical. Would I need something like eCalc or is there a relatively simple calculation that I can do? Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted January 18, 2023 Share Posted January 18, 2023 Yes Ecalc does this, Drivecalc (which is free) also does too. Both are very easy to use. If the motor you are looking at isn't in the database then just pick one with similar specs (e.g. rpm/volt and diameter) 2 Quote Link to comment Share on other sites More sharing options...
KenC Posted April 15, 2023 Share Posted April 15, 2023 Found this , if it is of any help. Quote Link to comment Share on other sites More sharing options...
Anton M Posted June 9, 2023 Share Posted June 9, 2023 This site might also be of help: https://rcplanes.online/setup_guidelines.htm Quote Link to comment Share on other sites More sharing options...
