Edgeflyer Posted February 14, 2023 Share Posted February 14, 2023 I am running Ethos on the X20 tx with a stabilised S8R Pro rx. I have the Rx setup. It does as expected in quick mode and advanced mode. Is there a way of using a momentary button as a panic button to get to self level from any other flight mode i.e. by overriding channels 11 and 10 to 0% and +100% respectively? Otherwise it means setting two 3 position switches to give self level mode. I knew how to set an override in OpenTx but it does not seem to exist as a special function in Ethos. Quote Link to comment Share on other sites More sharing options...
Edgeflyer Posted February 14, 2023 Author Share Posted February 14, 2023 Now sorted. Instead of the override special function Ethos uses the free mixer with its mixing function set to LOCK. This can set a locked condition on a particular channel according to, for example, a switch or button. I set up 2 free mixes to cause channels 10 and 11 to force to the required values when the panic button is pressed. Quote Link to comment Share on other sites More sharing options...
