ARCHER SR6 + X20S
Capt Kremen
Just updated a FrSky ARCHER SR6 Rx to latest V2.1.12.
Using a fully updated X20S Tx, the Rx is registered and bound OK, (Solid Green LED with power On).
No servo (AETRA set up) response EXCEPT Throttle on Ch3 which does operate thru full range.
Any clues what 'tick box' or other item needs changing to get the rest of the controls working?
The whole set-up worked perfectly before.
Brilliant!
Thanks GBG, 'ticking' self-check and waggling the sticks to all extremes did the 'blue' LED trick.
Whilst I love the flexibility of Open/Edge & ETHOS OS, the various tick boxes on the umpteen different permutations of model & receiver, can catch you, (or at least me),out.
Doesn't help when you haven't used or performed a specific set-up or task in a while ... soft memory fade occurs 😉
'Now how did I do that six-months ago?'
Yes, templates are good for repeats but as in this case, I'd updated to the latest spec. which can change or add things that weren't there last time!
