Garry Pollard Posted December 22, 2008 Share Posted December 22, 2008 HiWonder if anyone can give me a bit of advise once again. I operate a DX6i with an AR 6200 reciever and fly electric.. I have 2 art tech NIMH 1000 mah batteries and 2 GP NIMH 1300 batteries. My queery is when I plug in the art tech batteries the reciever lights go solid and system work ok, when the GP batteries are plugged in the reciever light continue to flash even though the system works ok. I do not want to fly with lights flashing until I have asked if it is safe. Have range checked with the 1300 batteries and checks out okHelp PleaseGarry Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted December 22, 2008 Share Posted December 22, 2008 Lights flashing usually mean that the system has seen a dip in power during operation, have you checked the voltage of the GP battery pack. Could be that you are making and breaking the circuit as you connect the battery, Rx sees a normal voltage and then low voltage and then normal voltage so it flashes to let you know that it's seen a loss in the power supply.Try switching the Tx off and then back on, this resets the Rx and the light should go solid and stay solid.By the way, are you switching the Tx on and off between swapping over battery packs? if not the Rx will just "see" this as a power failure and start to flash. Quote Link to comment Share on other sites More sharing options...
Garry Pollard Posted December 22, 2008 Author Share Posted December 22, 2008 Hi FrankThanks for the quick reply and advise. The last line was the key, no I wasnt swithing the TX off and on, went and tried it and worked perfect. Must be going more senile than I thought. Thanks for your timeRegards Garry Quote Link to comment Share on other sites More sharing options...
