3548/05 900KV TORNADO THUMPER V3 - BRUSHLESS OUTRUNNER RC MOTOR help
Lindsay Todd
Hi bought one of these motors looking to run on three cell lipo, once connected checked everything was running correct without a prop and all seemed good then fitted an 11x4 apc prop to check watts and the motor would not even turn over just sort of pulsed on the power. i did find that if i flicked the prop to spin then turn the power on the motor ran but this is an absolute no no i my mind. has anybody come across this problem before, batteries are fully charged 3cell 50c checked and ok.
Linds
Ok just swapped the motor with another from a good set up and getting the same problem so i am thinking the problem now has to be with the esc rather than the motor. I guess the next job is to check solder joints tomorrow, possibly re solder, then try alternate esc before committing to replacing the esc. Linds
