WHAT PROP FOR TIGERMOTH
Nick Funnell
18x10 would appear to be a good start
Remarks:
Battery
Load: 11.54 C
Voltage: 21.30 V
Rated Voltage: 22.20 V
Energy: 111 Wh
Total Capacity: 5000 mAh
Used Capacity: 4250 mAh
min. Flight Time: 4.4 min
Mixed Flight Time: 7.9 min
Weight: 858 g
  30.3 oz
Motor @ Optimum Efficiency
Current: 38.09 A
Voltage: 21.47 V
Revolutions*: 6298 rpm
electric Power: 817.9 W
mech. Power: 730.4 W
Efficiency: 89.3 %
Motor @ Maximum
Current: 57.69 A
Voltage: 21.10 V
Revolutions*: 5993 rpm
electric Power: 1217.1 W
mech. Power: 1074.1 W
Efficiency: 88.3 %
est. Temperature: 70 °C
  158 °F
Wattmeter readings
Current: 57.69 A
Voltage: 21.3 V
Power: 1228.8 W
Propeller
Static Thrust: 5911 g
  208.5 oz
Stall Thrust: - g
  - oz
avail.Thrust @ 0 km/h: 5911 g
avail.Thrust @ 0 mph: 208.5 oz
Pitch Speed: 91 km/h
  57 mph
Tip Speed: 516 km/h
  320 mph
specific Thrust: 4.86 g/W
  0.17 oz/W
Total Drive
Drive Weight: 1473 g
  52 oz
Power-Weight: 256 W/kg
  116 W/lb
Thrust-Weight: 1.18 : 1
Current @ max: 57.69 A
P(in) @ max: 1280.6 W
P(out) @ max: 1074.1 W
Efficiency @ max: 83.9 %
Torque: 1.71 Nm
  1.26 lbf.ft
Climb Capacity: 2177 m
  7142 ft
Airplane
All-up Weight: 5000 g
  176.4 oz
Wing Load: 42.1 g/dm²
  13.8 oz/ft²
Cubic Wing Load: 3.9
est. Stall Speed: 30 km/h
  19 mph
est. Speed (level): 80 km/h
  50 mph
est. Speed (vertical): 17 km/h
  11 mph
est. rate of climb: 8.2 m/s
( ~60...65° ) 1616 ft/min
Edited by Shaun Walsh
