Chris Dodd Posted November 30, 2023 Share Posted November 30, 2023 I have a 6 channel DMSS receiver and am having trouble mating the flap channel to aileron. I have done this numerous times before with seperate servo/channel for the ailerons, but on this occasion the model has retracts so I am using the gear port and the only available one is the aux1/flap channel. I have tried mating the gear channel and it works fine (as I have done many time before), but I cannot get the flap channel to mate. Any one have any ideas? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 30, 2023 Share Posted November 30, 2023 Guessing Chris I use 9X, is the Flap switch activated ? Quote Link to comment Share on other sites More sharing options...
Chris Dodd Posted November 30, 2023 Author Share Posted November 30, 2023 I have tried to go through each setting, changing flight mode, device settings etc. trying in various combinations to no effect. Thinking about it, I will double check the left aileron works with the flap switch with everything set to normal. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted November 30, 2023 Share Posted November 30, 2023 You tried different Aux numbers on TX ? Quote Link to comment Share on other sites More sharing options...
Chris Dodd Posted December 1, 2023 Author Share Posted December 1, 2023 16 hours ago, john stones 1 - Moderator said: You tried different Aux numbers on TX ? I have, just to try, but it is only a 6 channel receiver, and on the transmitter Aux1 isn't listed; but this is listed as Flap. Aux2 and Aux3 are obviously listed, but the receiver doesn't have those ports. Quote Link to comment Share on other sites More sharing options...
