Dai Fledermaus Posted February 28 Share Posted February 28 I've recently bought a Hobbywing Program Card and a Hobbywing Skywalker 40amp V2- ubec ESC. The program card comes with various labels to relabel it depending on the ESC brand and the application ie car, boat or aircraft. My problem is that the Skywalker ESC isn't covered on the program card instruction manual, although, clearly, both are made by the same company. I can only assume that the Skywalker range is new and the instructions for the card haven't been updated. The two yellow and black labels, supplied, are marked Table 1 for flyfun V5 and Table 2 for Platinum V1/V2 appear to be the only ones suitable for a model aircraft ESC Anyone know which label do I use? Quote Link to comment Share on other sites More sharing options...
John Lee Posted February 28 Share Posted February 28 It looks like the answer is - neither! Rather I suggest you use the Item - Value parameters as shown in the SkyWalker ESC instructions which vary from both of the stickers: 1 Quote Link to comment Share on other sites More sharing options...
Tim A Posted February 29 Share Posted February 29 Having researched the Hobbywing site it would appear the Skywalker V2 only supports the LED Program Box as shown here https://www.hobbywing.com/en/products/skywalkerv2.html I encountered the same issue trying to program the brake setting on a members new Skywalker V2. The box is the only supported means according to Hobbyking Quote Link to comment Share on other sites More sharing options...
Dai Fledermaus Posted February 29 Author Share Posted February 29 32 minutes ago, Tim A said: Having researched the Hobbywing site it would appear the Skywalker V2 only supports the LED Program Box as shown here https://www.hobbywing.com/en/products/skywalkerv2.html I encountered the same issue trying to program the brake setting on a members new Skywalker V2. The box is the only supported means according to Hobbyking It's very confusing Tim. The blurb on the Hobbywing website clearly says the program box supports the Skywalker V2 series. https://www.hobbywing.com/en/products/led-program-box_general82.html And the the Program box is show as an accessory on page for the aircraft range of Skywalker ESC's. https://www.hobbywing.com/en/products/skywalker-v2-series274.html I messaged Hobbywing in China two days ago, but I've had no responce as yet. I can of course programme the ESC using my transmitter, but as I've got the program card, I may as well work out how to use it. Quote Link to comment Share on other sites More sharing options...
