Alec Turnbull Posted May 16 Share Posted May 16 Not so much as a money saver as a time saver. Recently after a heavy ish (clumsy!) landing the tail on my Rex glider came adrift and snapped the inner part of the control snake, which was a SLEC lightweight, the one with a yellow outer and a white inner. I didn't have a spare long enough so as it was a straight run I just substituted a length of thin piano wire a bit stiff but as it was straight no problem. Fast forward a couple of weeks and this morning I was replacing the strimmer line on my electric strimmer, when finished I replaced it in the garage where it lives near my models and spied the old bit of snake lying on a work table and I suddenly wondered if the strimmer line would fit and work on the SLEC outer......well it does. This is what I used 1.6mm, bought on E Bay as i was too lazy to go to the garden centre Fits in the yellow outer and slides with no resistance A bit curley but when warm does tease straight, it needs to be cut with a sharp blade rather than side cutters. These snakes are quite expensive someone on e bay wanted £10 ish posted for a SLEC, now there are no model shops left I cant pop down the road and pick one up. 2 Quote Link to comment Share on other sites More sharing options...
Futura57 Posted May 16 Share Posted May 16 Now we just need a cheap alternative to the yellow outer tube 😀 Quote Link to comment Share on other sites More sharing options...
PDB Posted May 16 Share Posted May 16 (edited) 22 minutes ago, Futura57 said: Now we just need a cheap alternative to the yellow outer tube 😀 Would 3d printer bowden tube with an internal diameter of 2mm work? https://thepihut.com/products/ptfe-bowden-tube-for-1-75mm-filament Edited May 16 by PDB Quote Link to comment Share on other sites More sharing options...
Nigel R Posted May 16 Share Posted May 16 For commercial alternatives, Dubro Lazer Rods are still "reasonably priced", and are as good as the Sullivan fluted snakes (which are now silly money). The SLEC fluted blue/yellow ones are nearly as good but seem to have a slightly 'looser' fit by comparison, but still perfectly good for straight control runs. No connection beyond happy customer, etc. Quote Link to comment Share on other sites More sharing options...
