Glenn Philbrick Posted January 13, 2009 Share Posted January 13, 2009 Is it possible to use elevons with the DX6i transmitter and ar500 receiver I've tried the elevon mix in the tranny and the elevators are in opposite modes even if as ailerons they are correct.??Thanks.Glenn. Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted January 19, 2009 Share Posted January 19, 2009 Hi Glenn, I think you need to plug the right Elevon into the "Ail" ch2 port and the left Elevon into the "Ele" ch3 port then set your wing-type to "Delta" on your tx. Quote Link to comment Share on other sites More sharing options...
