LA RACER - UNDERCARRIAGE
Hi Guys
I am building a World models LA Racer and have found there is an offset built into the undercarriage legs.  If you put them in one way the wheel axles are just a fraction in front of the leading edge, when viewed from above.  If you swap the legs over the axles move to about two inches in front of the leading edge.  There is nothing in the instructions about this and the illustrations provided are no help.
I have also looked at the kit review by Graham Ashby in the June 2008 edition of RCME, but it is difficult to tell from the pictures which way round they fitted and there is no mention of this in the text.
I have built a number of models with this simple torsion bar type undercarriage and the legs have always been fully symmetrical.  If you were building this model and just fitted the legs as they came to hand it would be pot-luck which way round they went.  Perhaps Graham just fitted them and never realized!
 Anyway, does anyone know which is the correct position for the undercarriage on this model?
Regards
John Bennett
Hello John,
I would go the other way and put the wheels in line with the l/e...too far forward can make ground handling difficult, mainly ground-looping problems, but with them at the l/e, you will find landings and ground-handling much better. The model shouldn't nose over with the wheels in this position.
