Myron Beaumont Posted January 31, 2009 Share Posted January 31, 2009 Can't work out how to get channels 5 & 6 to do anything & can't get the channels to be as normal ie Ch 1 -ailerons , Ch 2 elevator ,Ch 3 throttle & Ch 4 rudder ( which only works on Ch 6 !) I can use the Tx it does work but the aforementioned Ch's 5 & 6 can't be assigned to anything (assuming I could transfer the rudder to Ch 4 ) On the Tx Ch 5 is called 5CH Gyro its a two position switch & Ch 6 is called Gear/ Pit and is a potentiometer. I'm only printing this 'cos I realise there are other sims that are similar so as maybe someone can tell me where I'm going wrong even if their Sim is different. ( if that makes sense ? ) Beginning to wish I'd been born a century earlier - It's all becoming too much for my remaining brain cell Quote Link to comment Share on other sites More sharing options...
Michael Hickman Posted January 31, 2009 Share Posted January 31, 2009 Hi Myron You can assign any(?) keyboard function to either of the addtional channels, enter the keyboard set up and click on the letter of the fuction to be assigned and then use the TX channel. Assigning rudder to 4 is completed wiythin the TX set up by mouse click on the interesection of channel (4) you wish and the function (rudder). Mike Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted January 31, 2009 Author Share Posted January 31, 2009 Michael Thanks I'm going to try it having written down your instructions Quote Link to comment Share on other sites More sharing options...
Michael Hickman Posted January 31, 2009 Share Posted January 31, 2009 Hi Myron Instructions are only from memory, and therefore maybe slightly inaccurate, but the principle should work. If you have problems and you think it might help I can start mine up and forward on a screen print? best wishes Mike Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted January 31, 2009 Author Share Posted January 31, 2009 Thanks Michael Have been busy " winding up " others on other threads so far . Will get the Sim on soon and try it 'Don't forget -If its not made of wood I don't really understand it ! Myron Quote Link to comment Share on other sites More sharing options...
