Nick Holmes 2 Posted February 7, 2009 Share Posted February 7, 2009 Hi guys, recently tried to change the prop on my Saito 125a, must have been a bit tight when originally fitted and you have guessed it will not come off. Have removed prop nuts etc but prop is stuck hard, any ideas the best way to remove? Thanks Quote Link to comment Share on other sites More sharing options...
winchweight Posted February 7, 2009 Share Posted February 7, 2009 There's a similar thread, but in essence you need to use a tool to stop the piston moving and then unwind the prop by hand. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 7, 2009 Share Posted February 7, 2009 Try a piece of wood through the exhaust port to "jam" the piston- then try turning the prop and easing it off. Otherwise it may require a puller. Alternative, suspend the engine upside down supported by the prop between two hard wood pieces / vice jaws etc.... and sharply hit the end of the crankshaft to see if it frees off the prop. If absolutely everything above fails, cut it off I guess Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted February 8, 2009 Share Posted February 8, 2009 " As the art mistress said to the mechanic " Sorry -Couldn't resist it . By the way Timbo the reason I couldn't insert smilies a short while ago was because I had increased the zoom feature on the lap top to 150 % & it wouldn't let me ! OK on 100% in other words NOT a fault of the new format which I'm quite happy with now .Well done y'all ! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 8, 2009 Share Posted February 8, 2009 Good - we are slowly getting there i think - although still around 30 items on the bug list. Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted February 8, 2009 Share Posted February 8, 2009 Take a look at this thread. Someone with similar problem and neat solution. Quote Link to comment Share on other sites More sharing options...
Bert Posted February 8, 2009 Share Posted February 8, 2009 Give it a blast with a heat gun, that should do the trick Bert Quote Link to comment Share on other sites More sharing options...
Keiran Arnold Posted February 8, 2009 Share Posted February 8, 2009 Err Didn't WOO do a bit in RCME a few month back on just this sort of problem??? Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted February 8, 2009 Share Posted February 8, 2009 Bert If you give the prop a blast with a heat gun you should add don't use it again! Quote Link to comment Share on other sites More sharing options...
Bert Posted February 8, 2009 Share Posted February 8, 2009 I was only suggesting to warm it up a bit - not melt it Bert Quote Link to comment Share on other sites More sharing options...
260 Flyer Posted February 8, 2009 Share Posted February 8, 2009 How to get the prop off a Saito! Quote Link to comment Share on other sites More sharing options...
