Peewhit Posted February 24, 2009 Share Posted February 24, 2009 Andy, Looking really good! Don't make it too pretty though, otherwise you will be very upset when it gets scratched / dented / lost / broken (delete as appropriate). Remember Andy Ellison's definition of SLOPE? :- Smashed Lost Or Pulverised Eventually!!!!!! It happens to the best of us. Good luck and looking forward to the maiden. Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted February 24, 2009 Author Share Posted February 24, 2009 Arrrrgggggghhhhh!!!!!!!! First major disaster, and its not even the maiden yet. I fixed the control horns to the control surfaces. I usually keep them close to the hinge line. Now the throws are huge and using EPA or rates just shows the resolution of the HS82mg to be grotty..... The million dollar question is how far ought I to move them back to tone it all down? Quote Link to comment Share on other sites More sharing options...
Peewhit Posted February 24, 2009 Share Posted February 24, 2009 Keep them close to the hinge line otherwise you will introduce unwanted aileron differential. Try moving the pushrods to more inner holes on either the servo, control horn or both. Best to keep the servos at full movement in order to keep the controls as soft as possible. Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted February 25, 2009 Author Share Posted February 25, 2009 Control throws now sorted. Mock canopy made from Solatrim in place. New rx battery on charge and 2 300mm extension leads bought. Just got to decide how best to keep the battery and rx in place....Suggestions? Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 25, 2009 Share Posted February 25, 2009 andy-sticky velcro is the lad-------------enrico is up your way today-don't know which hill he/they are at.................. ken anderson........................ Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted February 25, 2009 Author Share Posted February 25, 2009 Hmmmm.....and heres me sat at home doing nowt....... Quote Link to comment Share on other sites More sharing options...
Peewhit Posted February 25, 2009 Share Posted February 25, 2009 Would recommend enclosing the battery in a block of foam to absorb any shocks and prevent it bursting through the fuz in the event of a rough landing. Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted February 25, 2009 Author Share Posted February 25, 2009 Its done!!!!!!! Crammed all the gear and was unable to balance it. Hugely nose heavy. moved batter as far back as possible and still no joy. Ended up having to bury 20g of lead in the tail to get balance at 125mm from root leading edge. AUW 2lb 6oz and very yellow indeed. Cant wait for the next chance to maiden it. well, im going to ask someone to do this honour for me, truth be told. Pic to follow soon...... Ps...Many thanks to Peter and Kenny for all the help, advice and encouragement along the way.... Andy Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 25, 2009 Share Posted February 25, 2009 well done andy---nxt model? ken anderson............ Quote Link to comment Share on other sites More sharing options...
Peewhit Posted February 26, 2009 Share Posted February 26, 2009 Well done Andy, I could have maidened it today for you - been flying for five hours in a 30mph westerley to cure my withdrawal symptoms! The 20G of lead will provide useful ballast for windy days. If your Impulse flies half as well as my Bedlam (8oz of additional ballast on board) then you will have a good plane. If you fancy something small and fast, I can recommend a Multiplex Blizzard - they are quite fun to build as well - 65 notes plus gear and 100mph performance. Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted February 26, 2009 Author Share Posted February 26, 2009 Peter, You have no idea how much self restraint I have had to use to stop me getting a Blizzard. Got two things to finish off first though. A homespun Chilton DW1 I started see here And I have a cub that needs finishing, its been ongoing for over a year! I have brought the cub in from the garage and am looking at it now....Not sure it is worth a picture though Quote Link to comment Share on other sites More sharing options...
Peewhit Posted February 26, 2009 Share Posted February 26, 2009 Andy, Methinks that you are a little bit more experienced than you make out! This is about the fifth time I have flown my Blizzard. They are highly addictive and will fly in anything from 10mph to 40mph without ballast. Loops, rolls and spins are no problem - can't get it to complete a bunt though (bit more weight needed) - and very fast! Can't wait to get out there again! What's the weather forecast for this weekend? Forget the other projects and go get yourself a pet Buzzard! Quote Link to comment Share on other sites More sharing options...
Peewhit Posted February 26, 2009 Share Posted February 26, 2009 A little something to help convince you! Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted February 26, 2009 Author Share Posted February 26, 2009 Peter, I really have very little experiance both flying and building. Kenny can testify on that!!! The Chilton was a mad half hour and really way beyond my skills. I saw a picture on t'web and wanted one...... I suppose it will more than likely never fly or even get finished. Sum total of models built is a westwings Beguine, westwings Toucan. Arising star, easy glider and a zaggi.... Quote Link to comment Share on other sites More sharing options...
Peewhit Posted February 26, 2009 Share Posted February 26, 2009 Andy, You forgot the Impulse! It seems that you are just about ready for a Blizzard then, and if you need any help building it ........... Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 27, 2009 Share Posted February 27, 2009 peter-i was there when andy was watching one of our club member's flying a blizzard-we had to screw his eyes back into the socket's-me think's he's got one stashed away ready for the offski(keep's mentioning project x)5 cell lipo's- 500 watt outrunner's-80 amp bec's etc..etc.....etc ............. ken anderson............the spy........... Quote Link to comment Share on other sites More sharing options...
Peewhit Posted February 27, 2009 Share Posted February 27, 2009 Ken, It really is a crime to fit an electic motor and heavy lipo thing into a Blizzard. Mine is a pure slope soarer, and a brilliant one! My build was a bit non standard so when Andy does need some tips........ Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted February 27, 2009 Author Share Posted February 27, 2009 Well would anyone like to see the cub? Hopefully Uncle Kenny will maiden it for me and eventually give me my A cert with it too.... Quote Link to comment Share on other sites More sharing options...
Peewhit Posted February 27, 2009 Share Posted February 27, 2009 Andy, I would like to see the cub. Is it a bit bear at the moment (sorry, Yorkshire sense of humour). So what is this project X that Ken has let the cat out of the bag on? Nothing to do with high winds and wintry storms I hope! Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted March 1, 2009 Author Share Posted March 1, 2009 Ok Peter, as long as you promise not to laugh!!!! thats it as it stands....Vital stats are wingspan 49 inches.....all up weight minus prop and battery (yet to be decided upon) is 1pound 12 oz......Got a 250Watt rate motor in there already, 2 servos and rx.... If Uncle Kenny can make it fly i might even tart it up a bit..... Quote Link to comment Share on other sites More sharing options...
Peewhit Posted March 1, 2009 Share Posted March 1, 2009 Andy, Nice photo - like the floor! Cub looks very good and these high wing things, being very stable, fly well. Am sure you will get lots of fun out of it. However, for the slope theses are hard to beat:- Just like an Easy Glider only a bit faster! Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted March 2, 2009 Share Posted March 2, 2009 andy/peter................all model's will fly once-the cub will be fine-But methink's peter is on commision for the multiplex people the way he is pushing the blizardo's--he should put his in the post asap so we can give it the once over...................... ken anderson--on behalf of arthur dayley freeman and co................ Quote Link to comment Share on other sites More sharing options...
Andy Freeman Posted March 2, 2009 Author Share Posted March 2, 2009 Kenny, I think he wants to see my kids got to school in bare feet.Tempting me with that blizzard all the time. I am beggining to think that shoes for little boys might be a non essential, where as a blizzard IS. Quote Link to comment Share on other sites More sharing options...
Peewhit Posted March 2, 2009 Share Posted March 2, 2009 You've received the message Andy. Of course my kids go to school in bare feet. Have to get priorities correct. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted March 5, 2009 Share Posted March 5, 2009 andy - thank's for the lead i didn't get off you at the field ken anderson............ Quote Link to comment Share on other sites More sharing options...
