James M Posted February 12, 2009 Share Posted February 12, 2009 Hi All Ideally dreaming about what tx to buy next - I say dreaming as the price of them has shot up as the pound has dropped and priced me out the market for the moment. But I came accross these two on the horison hobby's website The AR6250 AR6250 DSM2 2.4GHz Full Range Carbon Fuselage Receiver With a minimal weight of just 4 grams the AR6250 DSM2 6-channel receiver is specifically designed for carbon fibre fuselage installations. Carbon fibre can create an RF shielding effect that can significantly reduce radio range when using conventional receivers and antennas. The AR9300 features an antenna design that resolves the critical issues presented by installations within this type of environment. And the AR9300 AR9300 DSM2 9-channel receiver optimised for carbon fibrefuselage installations With a minimal weight of just 18.23 grams the AR9300 DSM2 9-channel receiver is specifically designed for carbon fibre fuselage installations. Carbon fibre can create an RF shielding effect that can significantly reduce radio range when using conventional receivers and antennas. The AR9300 features an antenna design that resolves the critical issues presented by installations within this type of environment. Can't seem to find them listed on any UK websites to get a rough Idea of price but look good for the glider boys One question though, does fibreglass shield rf waves in the same way as carbon fibre ?? Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted February 12, 2009 Share Posted February 12, 2009 no Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 12, 2009 Share Posted February 12, 2009 Nice find there James...I will investigate further !# PS another "NO" from me too Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted February 12, 2009 Share Posted February 12, 2009 Right, having looked a littel closer at these "magic" Rx units I see that they are nothing more than regular single unit receivers with extended aerial leads as per the AR500 which has one of its aerial halves extended on small bore coaxial lead. These new versions have both parts of the single di-pole aerial on longer leads, with the active tip of the aerial on the end - which still needs to be outside the carbon fibre fuselage. Quote Link to comment Share on other sites More sharing options...
Andrew Clarke 3 Posted February 13, 2009 Share Posted February 13, 2009 well lets face it poking the aerials out of the fus does sort of resolve the issues. Quote Link to comment Share on other sites More sharing options...
