mike carroll Posted April 27, 2009 Share Posted April 27, 2009 I bought a used 50NG on the ground it starts fine, runs fine, transitions fine and you can hold the throttle anywhere at any rpm for any lenth of time and it runs fine. I guess buy now you are woundering why I am asking a question. Here is my problem, as soon as I roll out for take off and get the wheels about 2" off the ground I lose power, It does not die and idles fine and will power back up on the ground. WHAT IS GOING ON? I have also taken the carb apart and cleaned it, the only thing I can see possibly wrong is the diaphram is cupped. Thanks for anyones help in advance Quote Link to comment Share on other sites More sharing options...
Ultymate Posted April 27, 2009 Share Posted April 27, 2009 First thing Mike it could be adverse pressure effects on your daiphragm, there should be a small hole in the diaphragm cover and sometimes depending on the model and whats going on with air pressure inside your cowl / fuselage, try soldering a small pipe into this hole (you'll have to take the cover off to do this) make sure no sharp edges protrude inside as they will damage your diaphragm. Then when you've got it re-assemled run a length of fuel tubing down inside your fus where it can sit in relatively still air and see how your motor performs then. I had an extreme dose of this on a ZDZ 80 in an Extra and had to run the tube inside a 1"cube box of balsa in the fusalage. Strangely enough I have a ZDZ 50 in an Edge that gives me no problems Quote Link to comment Share on other sites More sharing options...
mike carroll Posted April 27, 2009 Author Share Posted April 27, 2009 Thanks for the info Ultymate, I'll give it a try Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted May 16, 2009 Share Posted May 16, 2009 I think I'm right in saying that new Walbro Carbs are supplied with a nipple already attached to the breather hole in the diaphram plate? The carb on my MVVS 45 certainly came with one. Edited By Doug Ireland on 16/05/2009 14:17:38 Quote Link to comment Share on other sites More sharing options...
mike carroll Posted May 18, 2009 Author Share Posted May 18, 2009 Well gentalmen I finally gave up on the old carb and bought a new one. Installed it on tuesday and went flying on Saturday. It worked without a flaw, don't know what got inside of the old one but it is now in the spare parts bin. Thanks for all your help Mike "Crash" Carroll Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted May 18, 2009 Share Posted May 18, 2009 Where did you get the new carb from? Quote Link to comment Share on other sites More sharing options...
mike carroll Posted May 18, 2009 Author Share Posted May 18, 2009 I bought it at Troy Built Models, here is the link http://www.troybuiltmodels.com it is not shown on there web side but if you E-Mail Mike Dooley he can sell you one. It was $55.00 USA and shipping. Mike Dooley used to work for RC Showcase the people that sold the ZDZ engines in the USA. Hope this helps you out Mike "Crash" Carroll Quote Link to comment Share on other sites More sharing options...
