Les Turrall 2 Posted May 1, 2009 Share Posted May 1, 2009 Can anyone advise me where I can buy a puller to remove the prop driver on a variety of IC engines? Failing that, can anyone advise me how these things can be removed other than by the application of heat and gentle persuasion with a hammer!! thanks in anticipation. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 1, 2009 Share Posted May 1, 2009 Les - your local market tool supplier guy should have one - I picked one up from my guy for a pound - not great quality of course, but does the job you need doing. Or heres one on fleabay that should be OK too Quote Link to comment Share on other sites More sharing options...
Les Turrall 2 Posted May 1, 2009 Author Share Posted May 1, 2009 Very many thanks Timbo. One fleabay puller should be on it's way to me shortly. Kind Regards. Les Turrall Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 1, 2009 Share Posted May 1, 2009 Quote Link to comment Share on other sites More sharing options...
Gaz Elliott Posted December 12, 2009 Share Posted December 12, 2009 What was the link as i need to remove a prop driver and not sure what i am looking for.. Cheers Gaz Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted December 13, 2009 Share Posted December 13, 2009 Machine Mart do a battery terminal puller that does the job, I've tested it on my 125 saito and an old ED hornet of 1.5 cc and for £8 or so it's well worth it. Other uses that it's been put to include, unsurprisingly, pulling terminals off batteries, and props that are on too tight too. Quote Link to comment Share on other sites More sharing options...
Gaz Elliott Posted December 13, 2009 Share Posted December 13, 2009 Would this remove the prop driver and collet from motors then. i have looked at it online but looks a bit small. May be just my mind playing tricks. Cheers Gaz Quote Link to comment Share on other sites More sharing options...
i12fly Posted December 14, 2009 Share Posted December 14, 2009 I couldn't find a puller when I wanted one, so..... I took a large washer which had an inner diameter very close to the groove in the prop driver. I then cut the washer in half and placed it in the groove. The engine was then placed in a loosened vice so that each jaw supported the cut part of each washer half, engine pointing down, shaft up. Placed the nut on the threads, about 2 turns to protect them. I made doubly sure the engine was free from the jaws, placed 1 hand under the engine to catch it and gave the end of the shaft a small rap with a wooden mallet. It works a treat on my Irvine 46, and cost was nothing. Quote Link to comment Share on other sites More sharing options...
