J V R Posted May 18, 2009 Share Posted May 18, 2009 I have just got hold of an AR6200 receiver, but the polarity of the pins are not marked, which one is +ve ? In the instructions it shows the binding plug, plugged in to the switch harness, as I don’t have a switch harness can I use another channel to bind the RX Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 18, 2009 Share Posted May 18, 2009 You can only use the bind plug in the "battery" socket of the Rx - and use any other socket temporarily for the battery / BEC. The polarity of the pins are shown on the case top, and I think from memory is negative on the bottom, positive middle, and signal top. Quote Link to comment Share on other sites More sharing options...
J V R Posted May 18, 2009 Author Share Posted May 18, 2009 Thanks Timbo, just had a close look at the case but can not see any +ve or -ve markings on it. Quote Link to comment Share on other sites More sharing options...
Alan B Posted May 19, 2009 Share Posted May 19, 2009 The servo signal lead usually white or yellow is against / towards the lettering on the Receiver i.e. thro rudd etc As Timbo says - Put the bind plug into the RX battery socket - plug your flight pack/battery into any of the servo sockets ( battery black lead at the bottom/edge of the receiver) and bind as per normal. Once bound dont forget to take out the bind plug!! Al Edited By Alan B on 19/05/2009 11:28:08 Quote Link to comment Share on other sites More sharing options...
Garry Pollard Posted May 19, 2009 Share Posted May 19, 2009 Adding to Alan B, take out the bind plug before swithing off. Guess how I know Garry Quote Link to comment Share on other sites More sharing options...
