Frank Corr Posted May 27, 2009 Share Posted May 27, 2009 Hi All, have just taken delivery of a Black Horse Mustang P51 and have to say the build appears to be excellent. However (always an 'However') the instruction manual appears to be sparse in a number of areas. I plan on installing a 4 stroke ASP in this model and was expecting information, in the instructions, about optimum distance from the firewall to the prop drive washer for a 4 stroke. The instructions have a template for the instillation of a 2 stroke and shows a distance of 120mm for the setting of the 2 stroke. Any thoughts on the appropriate distance at which the front of the engine should be set. (Other plans I have seen for a 4 stroke show a distance of appro. 135 mm to the prop drive washer) Many thanks in anticipation of all the good advice I know I will get on this forum. Frank Quote Link to comment Share on other sites More sharing options...
Andrew Clarke 3 Posted May 27, 2009 Share Posted May 27, 2009 hi frank,can't you trial fit the cowl and measure back to the firewall to get your distance. Quote Link to comment Share on other sites More sharing options...
