Patrick Checkley Posted June 19, 2009 Share Posted June 19, 2009 hi i would like to be able to boost my flight batteries at our flying feild, i have a xing 4-7 cell mini charger delta peak auto cut pulsed trickle charger giving a voltage output of 12.70 volts my trany bat. is rated at 9.7 volts would i do any harm to the battery ? Pat. checkley Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted June 19, 2009 Share Posted June 19, 2009 No Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted June 19, 2009 Share Posted June 19, 2009 Timbo Does that mean it's OK to connect a Tx nicad pack straight to a car battery & stop when things warm up ? Assuming a voltage of say 13 V ? If so -For how long starting from flat ? Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 19, 2009 Share Posted June 19, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted June 19, 2009 Share Posted June 19, 2009 Phil Gottcha Thats what I thought but no harm asking Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted June 19, 2009 Share Posted June 19, 2009 PS I suppose if I knew the internal resistance of the pack I could stick a nice bit wirewound resistor in series -Or is that a no-no as well? Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted June 19, 2009 Share Posted June 19, 2009 PSS I've only ever used the "wall" charger on Nicd's and never got out what is written on the pack according to my Wattmeter Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted June 19, 2009 Share Posted June 19, 2009 yes you could use a current limiting resistor, but frankly the risk of cooking your pack at the least, and worse dangers at worst means its simply not worth the risk. NiMHs do NOT like being overcooked and will die very quickly if the charge is not terminated at the precise time - one reason why many wall chargers are not suited to NiMHs being designed instaead for NiCD Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted June 19, 2009 Share Posted June 19, 2009 hello patrick-for year's i've used field charger's with my ni-cad's and the last couple of year's with my nimh's--to be honest the only time i use the supplied wall charger's is for a first charge-after that it is with the main's/field charger....this i use for my lipo's as well...........no prob's up to now............ ken anderson............ Quote Link to comment Share on other sites More sharing options...
Patrick Checkley Posted June 21, 2009 Author Share Posted June 21, 2009 many thanks for all your replys on the tx charging ? i will give it a try at the feild in future regards Pat Checkley Quote Link to comment Share on other sites More sharing options...
