Simon B Posted July 23, 2009 Share Posted July 23, 2009 I know it said 95% ready built, but even i was amazed: I'm a slow builder and i'm still waiting for the motor to arrive, but i've ran out of things to do. Next was putting the wheels and spats on: I didn't even have to use glue on the tail, as it bolts on (although i might change this): Quote Link to comment Share on other sites More sharing options...
Simon B Posted July 23, 2009 Author Share Posted July 23, 2009 The servo holes even had thread in them for you to pull the wires through! This is far too easy... Hopefully my motor will arrive tomorrow, but here's the last two pics before i go to bed: Quote Link to comment Share on other sites More sharing options...
paul@scc Posted July 24, 2009 Share Posted July 24, 2009 Posted by Simon B on 23/07/2009 23:18:51: I didn't even have to use glue on the tail, as it bolts on (although i might change this): No need to change. One of the great things about this plane, if you want to travel with it you can unbolt and get it back in its own box. The stock spinner needs a little bit of carving. I think she looks a lot better with one of these. The extra bit of weight also helps with the COG. Quote Link to comment Share on other sites More sharing options...
Andy Harris Posted July 24, 2009 Share Posted July 24, 2009 It'll fly well .... Andy Quote Link to comment Share on other sites More sharing options...
Andy Pickford Posted July 24, 2009 Share Posted July 24, 2009 Im thinking about one of these myself. Is it a one piece wing or did you have to join it? Andy Quote Link to comment Share on other sites More sharing options...
Simon B Posted July 24, 2009 Author Share Posted July 24, 2009 It's a one piece wing, so absolutely nothing to do it. Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 24, 2009 Share Posted July 24, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Simon B Posted July 27, 2009 Author Share Posted July 27, 2009 Motor arrived today. Servo extension leads did not. Bah. Quote Link to comment Share on other sites More sharing options...
Andy Pickford Posted July 27, 2009 Share Posted July 27, 2009 What size motor and battery are you using? Quote Link to comment Share on other sites More sharing options...
Simon B Posted July 27, 2009 Author Share Posted July 27, 2009 Hi Andy, it's a 220w, 880kv motor and a 11.1v, 2800mah Li-Po. Hopefully going to try it out tonight... Quote Link to comment Share on other sites More sharing options...
paul@scc Posted July 27, 2009 Share Posted July 27, 2009 Hi Simon.I think your lipo will have to slide at least half its length backwards to get the correct CoG. Unless your going to add lead to the tail. Quote Link to comment Share on other sites More sharing options...
Simon B Posted July 27, 2009 Author Share Posted July 27, 2009 I've just checked the CoG and you're not wrong! Even when i slide the battery back as far as it'll go it's still massively nose heavy. I'll have to get a ton of lead weight or use a lighter battery... Quote Link to comment Share on other sites More sharing options...
