zlin50 Posted August 3, 2009 Share Posted August 3, 2009 Hi I am thinking of buying this model - can anyone tell me if an SC 70 FS would be a suitable power plant. regards Hans Quote Link to comment Share on other sites More sharing options...
andy watson Posted August 4, 2009 Share Posted August 4, 2009 A 70 should be a cracking engine. My mate has one that he tried to fly on the recommended 52FS, and whilst it would just about fly, he thought it was very underpowered (it should be borne in mind that his throttle is more like an on/off switch though!). I think it might have been a 70FS he went up to. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted August 4, 2009 Share Posted August 4, 2009 Agree a 70 four-stroke, there's plenty of room under the cowl. Quote Link to comment Share on other sites More sharing options...
Tony Stead Posted October 20, 2009 Share Posted October 20, 2009 I have the gillmore red lion 54 inch i need help as i have not got the manual to go with it and needs a repair on the undercarriage if someone has it could you please email me Many Thanks Tony Quote Link to comment Share on other sites More sharing options...
zlin50 Posted November 4, 2009 Author Share Posted November 4, 2009 Hi guys Does anyone have any suggestions for the best way to extend the fuel needle control through the large cowl of the Gilmore racer. It must be sufficiently long to turn by hand when the engine is running but short enough or flexible to allow the cowl to be manoeuvred into position. regards Hans Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted November 4, 2009 Share Posted November 4, 2009 You can buy Os extensions that are a flexible wire,once the cowl is in place you then put a circular knob on the end held in place with a grub screw Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 4, 2009 Share Posted November 4, 2009 Solid wire extensions to needle valves are often the cause of poor running due to the extra vibration transmitted back to the delicate tolerances of the needle assembly. The recommended system is to use something like a piece of fuel tubing over the end of the original needle, and then use this as a guide to insert a small screwdriver / allen key whatever into the end of the needle and adjust. Quote Link to comment Share on other sites More sharing options...
zlin50 Posted November 6, 2009 Author Share Posted November 6, 2009 Thanks for the help guys I will try out your suggestions regards Hans Quote Link to comment Share on other sites More sharing options...
