Olly Giles Posted August 31, 2009 Share Posted August 31, 2009 quick question. Has anyone bought one and flown it. What is you opinion on it, especially regarding build quality as i have had an Infinity 90 from probuild and the build quality is poor, which is a shame as in the air it is second to none. ThanksEdited By Oliver Giles on 31/08/2009 18:37:33 Quote Link to comment Share on other sites More sharing options...
Olly Giles Posted August 31, 2009 Author Share Posted August 31, 2009 I will put a pumped YS110 on a short hatori short tuned pipe in it if i do get one. Anone used this set up? Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted August 31, 2009 Share Posted August 31, 2009 Yes I have bought one and have been flying it this summer when I can. I have been using an OS 120Fs pumper with a 14x10 APC. I must say it flies very well and does all the areos you could wish for, although landing needs care if you slow it up too much. Which brings me to my next point - the U/C arrangement is pitiful with the legs on it no bigger than on my Cmpro Quest 50 and expected to carry 3x the weight. Also the U/C being so short it's easy to foul the prop on the floor with a bouncy arrival. Also the ply plate housing the U/C is not up to scratch and gaveway on the second flight. I replaced it with 1/4" birchwood ply sheet and epoxy resin bandage, this has solved the problem. I also bought a better UC from Carboncopy. Hope this is useful. Quote Link to comment Share on other sites More sharing options...
Olly Giles Posted August 31, 2009 Author Share Posted August 31, 2009 thanks adrian, you may have steered me away as i cant afford an UC to let go as a puncture in the pressurised system results in a hosepipe effect iside the model. Never mind i will just keep looking. Quote Link to comment Share on other sites More sharing options...
