Yorkman Posted October 2, 2009 Share Posted October 2, 2009 is there any way (like soaking balsa) that depron can be treated to make it more flexible, so it can be rolled around a L/E for example? Quote Link to comment Share on other sites More sharing options...
birdy Posted October 3, 2009 Share Posted October 3, 2009 There is an artical somewhere on this sight I think, where Cyril Carr (Is that the write name?!) made a depron space shuttle, and explains how he rolles depron. Quote Link to comment Share on other sites More sharing options...
Chris Card Posted October 3, 2009 Share Posted October 3, 2009 If you score the inner surface of the depron at regular intervals, it curves nicely. This link explains well, along with details of building a full depron wing: http://webx.dk/rc/depron.htm Edited By peevie on 03/10/2009 09:55:06 Quote Link to comment Share on other sites More sharing options...
Yorkman Posted October 3, 2009 Author Share Posted October 3, 2009 thanks for that-the answer's no, then! Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted October 3, 2009 Share Posted October 3, 2009 Yorkman As far as I know the only way to "soften" Depron is to heat it, but it has to be at exactly the right temperature and uniform over the required area, not easy to do. I does however have a "grain" so it bends better one way than the other and of course the thinner the sheet the easier it bends. The complete LE of my Hamilcar ahead of the spar is a single 2mm sheet bent round, no heat, no scoring, just finger pressure and UHU POR. Quote Link to comment Share on other sites More sharing options...
Yorkman Posted October 4, 2009 Author Share Posted October 4, 2009 now that's what I wondered-if that could be done. Looks good Simon. Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted October 5, 2009 Share Posted October 5, 2009 Another trick for bending depron is to cover the outside of the curve with brown parcel tape before trying to shape it. This will help to stop it cracking.Edited By Bruce Richards on 05/10/2009 08:58:23 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted October 5, 2009 Share Posted October 5, 2009 Bending Depron by Cyril Carr here. Edited By David Ashby - RCME moderator on 05/10/2009 08:49:30 Quote Link to comment Share on other sites More sharing options...
Mowerman Posted October 5, 2009 Share Posted October 5, 2009 Also see www.rcgroups.com/forums/showthread.php?t=385446 The above will show you how others have done it and built some great models. Quote Link to comment Share on other sites More sharing options...
