mark heffer Posted November 11, 2009 Share Posted November 11, 2009 I have fitted a power pod to a slope glider 130ish watt should be fine but. The high thrust line seems to push the nose down in my hand and a test glide was fine until the power was put on the nose went down straight away. No damage but that was it for the day. I have up thrust in the pod and the C.G. of the plane is fine .any ideas . Cheers Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted November 11, 2009 Share Posted November 11, 2009 More up thrust required. If the thrust line is well above the wing quite a lot may be needed. It's a leverage thing.... I think the thrust line is acting against the centre of pressure which might explain why it feels like it's pushing the nose down when you're holding it. Edited By Martin Harris on 11/11/2009 22:41:55 Quote Link to comment Share on other sites More sharing options...
Slopetrashuk Posted November 11, 2009 Share Posted November 11, 2009 Yep - More up thrust needed here. You'll maybe need +4-6 degrees. Andy Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 14, 2009 Share Posted November 14, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
mark heffer Posted November 16, 2009 Author Share Posted November 16, 2009 Thanks all, that makes sense and yes the short fuz big prop looks a bit silly but we will see how it goes now when the wind stops. Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted November 18, 2009 Share Posted November 18, 2009 I have used power pods equipped with Cox Baby-Bee 0.049 motors on gliders up to 100" wingspan and the thrust line on those was much the same as Eric is suggesting with the rear end of the thrust line pointing around the tail of the fuselage. Seemed to work for me especially with no posibillity of shutting the motor down until the motor runs out of fuel ! Quote Link to comment Share on other sites More sharing options...
