The Futaba FF8-8FG
That latest V4 update has a nice feature that allows quick changes between your 4 most popular models without delving deep into the menus which I've found most useful.
With the download you get a couple of PDF files which firstly tell you how to do the update and the second is an adendum to the manual to tell you how to use the new facilities.
David go into the 4 page main menu and on page 4 if you've done the update the last item will have the heading "start sel" this is the one you want to customise the start up screen. The instructions for the setup are in the aforementioned PDF.
