Rod Levin Posted April 10, 2010 Share Posted April 10, 2010 I read and have the included plan (in the RCM&E March 2010) of Peter Miller's C/L Super Trooper. Can anyone give me practical ideas to turn this into a three-channel Radio Controlled model, please ? TIps on engine size, position of C of G, other ? Many Thanks Rod Levin - London Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 18, 2010 Share Posted April 18, 2010 Ye Gods, even I wouldn't attempt to do that. Well, For a start, take it to your local print shop and get it enlarged to at least 48" span. That way you will have room to fit some radio gear. Then add about four degrees of dihedral to the lower wing and a couple to the top wing. For the CG, Drop a line down from two inches behind the leading edge of the top wing and mark a line up two inches from the leading edge of the bottom wing. divide the gap in half and that should be a safe CG Finally fit a .40 Surpass four stroke engine or an SC 32 two stroke. I am not Guarenteeing that it will work but it is what I would try. Why three channel? Four would be much better. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 18, 2010 Share Posted April 18, 2010 Actually a .52 four stroke would be better for a four channel model Quote Link to comment Share on other sites More sharing options...
Rod Levin Posted April 23, 2010 Author Share Posted April 23, 2010 Peter, Many Thanks for your reply - I see that my idea is quite an undertaking ! To me, you have created beautiful lines in the Super Trouper and would like to see it under R/C. If I get that far, I'll report back. Happy Landings ! Rod Levin Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 23, 2010 Share Posted April 23, 2010 Wait until you see the model that I am just finishing. a fully elliptical biplane 45" span for .52 four strokes. Quote Link to comment Share on other sites More sharing options...
Rod Levin Posted April 23, 2010 Author Share Posted April 23, 2010 Sounds Good - I'll look out for it ! Thanks for tip-off Rod Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 30, 2010 Share Posted April 30, 2010 Just finished but not test flown Quote Link to comment Share on other sites More sharing options...
Pete Stevens Posted April 30, 2010 Share Posted April 30, 2010 WOW! what a plane, will there be plans for this!!! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 30, 2010 Share Posted April 30, 2010 Another view Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 30, 2010 Share Posted April 30, 2010 There will be if it flies OK. 45" span. .52 foru stroke, five square feet of wing area and only weighs five pounds, that is low wing loading. Here is a picture of the family Quote Link to comment Share on other sites More sharing options...
Rod Levin Posted April 30, 2010 Author Share Posted April 30, 2010 Hi Peter, Congratulations - I think you have created another 'Beauty' with this R/C eliptical winged Bipe. Does it have a name yet ? Good luck with the flight trials, I will look out for the write-up and plan. Also, from the 'Family' pic, what is the name of the white monoplane (with red and blue star bursts) - please ? Many Thanks Edited By Timbo - Administrator on 30/04/2010 21:57:12 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 1, 2010 Share Posted May 1, 2010 The biplane is called Melody. The whitre monoplane is Symphony and is avalable as a plan from Traplet Publications. I am particualrly pleased with the cowling on that model. styles on the Avro Shackleton cowls it hides an engine and Silencer in the cowl while not being a huge diamter. SC32 Rhapsody (Red and yellow high wing) is an AMI plan and always fools people, they think she is a vintage model until they see her doing every stuntb in the book.SC32 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 22, 2010 Share Posted May 22, 2010 Well, Melody has been flown and is very nice indeed. One point, no way can it be flown on rudder only, ailerons are essential. Quote Link to comment Share on other sites More sharing options...
Rod Levin Posted May 22, 2010 Author Share Posted May 22, 2010 Hi Peter, Many Thanks for the pre-view / update. I see that Melody certainly 'sits right' in flight. Presently, I am being enthralled by your write-up and production of Harmony in the current RC&ME. Keep up these Grest Achievements ! Rod Quote Link to comment Share on other sites More sharing options...
