CARPERFECT Posted June 2, 2010 Share Posted June 2, 2010 Got a very hot running std motor in my multiplex easy glider, so hot that it`s melting the foam. i am running a 2 cell lipo ,and a Turnigy 30 amp esc. what voltage should be going to the std 400 size brushed motor ? I have checked it and getting 8.4v with a fully charged lipo Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted June 2, 2010 Share Posted June 2, 2010 It may be that your propeller is too big, if I remember correctly a 400 motor can only take about 10Amps. The voltage is less important. You could really do with measuring the current draw and try different props until the current is below 10A. Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted June 3, 2010 Author Share Posted June 3, 2010 The propeller is the one that came with the motor and the glider . the instructions say a 18 amp esc is required. Even when i have the motor running as slow as it will go it gets that hot that you can not touch it Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted June 3, 2010 Share Posted June 3, 2010 A speed 400 motor should be OK on a 2s lipo ( 7.4V ), as its designed for 8 cell nickel ( 9.6V ) and as your ESC is rated well above the standard unit, thats no problem either.Is the motor new, or badly worn, binding , clapped out brushes etc ? Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted June 3, 2010 Author Share Posted June 3, 2010 All new this xmas. The Turnigy esc only lasted 5 mins when the brake stopped working , This was replaced FOC So this was only its second flight. The brake stopped working again after 5/10 mins . we had 4 flights and noticed the motor getting very warm.the last time the motor had started to melt the foam and was smoking. we were not flying on full power. only using motor when reqired. as said earlier just running motor very slow at home will had the motor getting that hot that you can not touch it Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted June 3, 2010 Share Posted June 3, 2010 I thought the easy glider came with motor and ESC supplied - in which case these would be mpx branded escs not turnigy? Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted June 3, 2010 Author Share Posted June 3, 2010 No only the RR one comes like that . The ARTF only comes with motor Quote Link to comment Share on other sites More sharing options...
Eamonn Fahey Posted June 4, 2010 Share Posted June 4, 2010 Is your Turnigy 30A controler a Brushed Motor controler? I had a problem with overheating using a Turnigy 30A Brushed controler. I discovered that one of the brushes on a new motor had come off which let the brass brush holder rub on the commutator. I replaced the motor and had no more overheating. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted June 4, 2010 Share Posted June 4, 2010 I guess it must be as he is still using the original brushed 400 motor AFAIK Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted June 7, 2010 Author Share Posted June 7, 2010 Can anybody recomend a brushless setup to go in the easy glider. ( and not the over priced one from Multiplex) Quote Link to comment Share on other sites More sharing options...
Capt Kremen Posted June 7, 2010 Share Posted June 7, 2010 A cheap but very, very effective set-up is: HET Typhoon 15/13 £25-00 + suitable 25-30A Speed Controller Swings a 11 x 4.7 prop (or similar Graupner CAM Prop folder 3.17mm shaft size) 3cell LiPo 2500mAh pack, you'll be up for a minimum of 30mins without thermals! Super climb out to 'speck-in-the-sky' height too. http://www.giantcod.co.uk/typhoon-outrunner-1513-p-405108.html 'Electric Aeroplane Company' used to sell these motors too but perhaps HET are no longer in general circulation/use(?). Some surgery needed on the fuselage nose to allow fitment of a front former, easy enough though. My 'Easy Glider' is now 5 years old and still flying (well) on this motor. Wings a bit 'sloppy' and loose fitting on the 'stronger' carbon rod spar I substituted for the kit supplied one. Full up ailerons don't have a great deal of effect as spoilerons on mine, it still goes up in strong lift with them deployed!!! Quote Link to comment Share on other sites More sharing options...
