Delta Whiskey Posted July 5, 2010 Share Posted July 5, 2010 Just wondered if anyone has tried one of these models, just seen myslef from RCME Gliders UK Advert? I have a ST Models MX2 and it's a little underpowered but otherwise holding up well, but have always fancied the Multiplex Blizzard, but put off by the high cost of the Tuning kit (model price itself was within budget) so whilst I suspect performance will not be as fast, seems ideal for a bit of aerobatics and fast passes along with the chance of catching a thermal or two? Anyone comment of what I can expect or as a comparassion to the Bizzard?Edited By Delta Whiskey on 05/07/2010 12:40:23 Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted July 5, 2010 Author Share Posted July 5, 2010 Just found a video on youtube - looks impressive, just wonder if it's a stock motor one though! http://www.youtube.com/watch?v=6VV5lZwKHwc Edited By Delta Whiskey on 05/07/2010 13:00:31Edited By Delta Whiskey on 05/07/2010 13:01:26 Quote Link to comment Share on other sites More sharing options...
Paul Posted July 5, 2010 Share Posted July 5, 2010 Hi, User review from this site here - blaze I fancy one of these myself, had the same thoughts about the MX blizzard as well. Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted July 5, 2010 Author Share Posted July 5, 2010 Thanks, it shows Overall: A very well designed aerobatic warmliner that is extremely good value for money. So a warmliner sums it up, not quite a hotliner but I am still tempted as I'm not for all out speed, just some gliding some speed & basic areobatcis! There's a couple of Blizzards at my patch, and the do shift ! Also make a nice whislting sound too. Edited By Delta Whiskey on 05/07/2010 13:15:12Edited By Delta Whiskey on 05/07/2010 13:15:48 Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted July 6, 2010 Author Share Posted July 6, 2010 Again for me Brentford Models comes out the cheapest at £107.95, might pop over and get one later this week ! Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted July 6, 2010 Share Posted July 6, 2010 I've had one for a couple of weeks now. It flies very smoothly and the motor is quite powerful. It will climb almost vertically from a hand launch. Wingtips are quite thin and can suffer a bit on landings (guess how I found that out) At first the glide was not good, but I found that I had positioned the battery too far forward. It needs to be right back in the compartment under the wings. I think that the CG position is critical for good performance so it will pay to set it up carefully. Great value for money! Happy landings Pete Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted August 9, 2010 Share Posted August 9, 2010 I bought one of these Blaze's today...well, Ive just got out of hospital so gotta do something! I'm impressed with it so far, hope to fly tomorrow. Dvaid Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 9, 2010 Share Posted August 9, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bill_B Posted August 11, 2010 Share Posted August 11, 2010 Posted by Tom Sharp 2 on 09/08/2010 18:44:51: ..... It is not a thermal soarer. It is off the slope. I have fitted a 10" x 7" Aeronaut carbon prop in place of the supplied 10" x 6" and it will climb truly vertical with good authority. Also, the 4mm Blizzard spinner assembly can be made to fit and the colour matches the decals perfectly. Talking of decals, if they are ironed on with a very low heat (and a cotton sole cover) they adhere very well indeed. Outstanding for the price! Quote Link to comment Share on other sites More sharing options...
Simon Rigby Posted September 11, 2010 Share Posted September 11, 2010 Next plane on from first flights with a trainer and love it to bits (hopefully not literally)! This plane does everything I ask of it and is very docile in the stall as well. The wing tips will eventually suffer with landings (well - mine anyway!). Get one now! Word of warning to JR TX users - the delta tail function on JR TX's will not work correctly on this as the servo's are top mounting, not bottom. I ended up having to make my own custom mix, but it's not hard. Quote Link to comment Share on other sites More sharing options...
iawnski Posted November 29, 2010 Share Posted November 29, 2010 any tell me how to get the brake on the motor to work as i havent got any instructions pleas e Quote Link to comment Share on other sites More sharing options...
r6dan Posted November 29, 2010 Share Posted November 29, 2010 DW,Multiplex tuning kits are well overpriced just look at the speck of the kit in the tuning kit and match the parts up yourself online,you will save at least 50% by doing it yourself. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted November 29, 2010 Share Posted November 29, 2010 Posted by iawnski on 29/11/2010 16:30:09:any tell me how to get the brake on the motor to work as i havent got any instructions pleas e The motor is not the thing that brakes kev - its the ESC. You need to set the ESC to brake mode - what ESC is it? Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted November 29, 2010 Share Posted November 29, 2010 According to the destructions, to turn the brake on: Disconnect the battery with the airplane before operation switch. (I think that means disconnect the motor from the ESC and also the battery from the ESC) Move the throttle stick forward to its highest place. Plug the battery to the fuselage. (I assume that means to the ESC).wait for 5 seconds, there will be two beeps.Move the throttle stick backwards to its lowest place. There will be two more beeps. The power system will now work with the brake on, or as the instructions put it: And move throttle down to the lowest, ESC will have a beep indicating prop brake off and now the ESC is activiated (sic) to motive the prop. Good Luck! Quote Link to comment Share on other sites More sharing options...
iawnski Posted November 29, 2010 Share Posted November 29, 2010 thanks peter will have a go in the morning to cooollllllllllllldddddddddddd in there at the mo ,timbo yep its just the way i word em he he Quote Link to comment Share on other sites More sharing options...
iawnski Posted November 30, 2010 Share Posted November 30, 2010 timbo its the one that comes with it no name on it either Quote Link to comment Share on other sites More sharing options...
iawnski Posted November 30, 2010 Share Posted November 30, 2010 hi peter thanks for the info just tried it and sorted 1st time cheers iawnski Quote Link to comment Share on other sites More sharing options...
Broken Prop Posted December 1, 2010 Share Posted December 1, 2010 Glad you got it sorted out (in spite of the the Chinese Engrish) Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted March 22, 2011 Author Share Posted March 22, 2011 Well since I started this thread.....I've actually gone out and got one, maiden yesterday and used 2 packs, with 4 more packs today and wow very impressed to say the least ! Nice touches like velcro already in place in the fuz and extra supplied to fit on your batteries easy to put together and if your Tx has the V tail option like my Futaba 7C does easy to setup on radio too. Today after getting more used to it I hand launched it and then pulled straight up vertically ! Next flight another club member held it at 45 deg and just let go as I put on full throttle again pulling vertical ! Very impressed so far, and after putting on the Esc brake it glided longer and faster and makes a nice whistling sound as it passes you in a dive ! Only negative so far was applying those stickers that seems to be a triat of ST models (see my MX2 assembly thread) - I stuck my own high vis red stripes on the underside of the wing but it did'nt help much seeing those slim wings way up after a step climb out ! Looking forward to my next outing on Thursday ! Need to get some 30C batteries if the ESC rating will handle them? Quote Link to comment Share on other sites More sharing options...
JOHN BOWMAN Posted March 22, 2011 Share Posted March 22, 2011 Iawnski, Following your demonstration of the Blaze on the Orme at our Xmas fly in I bought one and it is a brilliant model for the money, or just a brilliant model. Now you should have asked me how to brake the motor, it is one of the few things I actually know how to do!!!!!!!, My big chance to impress and you did not ask, Gutted, John B Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted March 23, 2011 Share Posted March 23, 2011 I must be at around 60 flights with mine and still very impressed. It's one of those models that I never seem to tire of and has been a good hack through the winter months. One of those that I can honestly say 'I'd buy another' if something happened. Quote Link to comment Share on other sites More sharing options...
iawnski Posted March 23, 2011 Share Posted March 23, 2011 nice one john told you it was good ,next time i have a prob john ur 1st in line cu at the orme soon i hope Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted March 23, 2011 Author Share Posted March 23, 2011 got 4 packs charged and ready for tomorrow ! Quote Link to comment Share on other sites More sharing options...
Bill_B Posted March 24, 2011 Share Posted March 24, 2011 Posted by Delta Whiskey on 22/03/2011 22:10:08: Only negative so far was applying those stickers that seems to be a triat of ST models (see my MX2 assembly thread)................... ST Model's decals are fine if once you've applied them they're sealed into place with a covering iron on low heat (with a cotton sole cover). I've used this technique on many foam planes and have never had any decals come prematurely unstuck (I have an MX2 too). The warm iron technique also works extremely well with 'Fablon'. Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted April 16, 2011 Author Share Posted April 16, 2011 Have to say - still loving this model - umpteen packs used and it can poodle about gently or zoom around and love the whistling noise on a fast low pass ! Flown in the nice calm weather we've been having down south recently as well as in 15mph winds with ease earlier this week! Quote Link to comment Share on other sites More sharing options...
