Chris Smith 2 Posted August 25, 2007 Share Posted August 25, 2007 Following a crash yesterday (a tree jumped out in front of me) my Arising Star needs repair to the fuselage. I notice that the sides are constructed of 3/16 ply. I am finding difficulty in locating 3/16 ply in any of the model shops. Can someone please point me in the direction of a supplier.All the bestChris Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted August 26, 2007 Share Posted August 26, 2007 3/16 ply? I doubt it. Most likely laminated from two pieces of 3mm liteply. Available from any model shop. Sounds like a bit of an overkill to me. Must weigh a ton! By the way, I offer a build/repair service. Regards, MM. Quote Link to comment Share on other sites More sharing options...
Allan Jordan Posted August 27, 2007 Share Posted August 27, 2007 Hi Chris, Like Martin I cant see the Fuz. built from 3/16 ply. Are you measuring at a doubler point. Most model shops stock 1/8 ply. I have looked in all of B&Q type stores hoping to find 1/8 ply with no success at all. Best of luck with the repair, hope it's flying again soon. AllanJ...TTFN Quote Link to comment Share on other sites More sharing options...
Rick Messenger Posted September 29, 2007 Share Posted September 29, 2007 Hi Chris. I had some great fun with the arising star when I first started flying. Best way to repair is to use some 1/8th ply from your local model shop and laminate it with some balsa to give you the same thickness as the original fuz. Dont worry it will be well strong eough, use the old damaged section(s) as a pattern and graft into onto the fuz.Good luck with the repair and get it flying again.RegardsDeadwood Quote Link to comment Share on other sites More sharing options...
