'Widget' Posted August 12, 2010 Share Posted August 12, 2010 Hi again, Does any one know the correct control throws on the 1/5th scale Pica Jungmeister please. Also I would like a copy of the drawing if possible and any other useful hints and tips from anyone regarding this model please. Regards, ' Widget' Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 14, 2010 Share Posted August 14, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 14, 2010 Share Posted August 14, 2010 not a Pica, but mine is happy with as much aileron as possible (around 3/4" each way I think) but not so much elevator, maybe 3/8-1/2", any more and it flicks unintentionally. Rudder, again as much as you can get for nice crisp flicks/spins.So far I've not been able to get it all the way round , it insists on rolling out at about 30 degrees past inverted. Quote Link to comment Share on other sites More sharing options...
Pete B Posted August 14, 2010 Share Posted August 14, 2010 There's a bit on here re C of G,Widget, and it may be worth searching further: http://rcudev.rcuniverse.com/forum/m_2110279/anchors_2111601/mpage_1/key_/anchor/tm.htm#2111601 Pete Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 15, 2010 Share Posted August 15, 2010 "So far I've not been able to get it all the way round" - missed out the words 'outside loops' - inside are fine, but outside it runs out of speed on the climb back up and falls outEdited By Bob Cotsford on 15/08/2010 11:35:58 Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 15, 2010 Share Posted August 15, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
'Widget' Posted August 15, 2010 Author Share Posted August 15, 2010 Thanks everyone, a good start point. Still would like to copy a drawing though. Cheers Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 15, 2010 Share Posted August 15, 2010 Eric - you are an education, I had always thought bunt was just the old term for an outside loop. It's pretty much a flat bottom section, inverted doesn't use a huge amount of down but being quite hefty for it's wing area it soon runs out of steam in the inverted climb section. It needs to lose a lb or more in weight or grow another 6" span.That or stick to inside loops. Quote Link to comment Share on other sites More sharing options...
