BB Posted August 17, 2010 Share Posted August 17, 2010 If I add 1/2 gallon 10% nitro to 1/2 gallon 5% nitro what am I ending up with ? 15% 10% 7.5% Anyone ? BB Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted August 17, 2010 Share Posted August 17, 2010 My vote's for 7.5 % - it gets trickier if you want to add one component e.g. nitro-methane as the oil and methanol percentages are then changed and it then takes a bit more thought to work out how much oil to add to maintain the same oil percentage. The only other possible complication is if you're using 2 different makes and one measures by weight and the other by volume... P.S. the only other other possible complication is that one fuel may have a different oil which might just conceivably have mixing problems but I don't think that's very likely. Whatever you use, mixing 50/50 will average whatever you've got! e.g. Fuel 1 - 73% Methanol 15% synthetic 2% castor 10% nitro Fuel 2 - 80% Methanol 15% synthetic 0% castor 5% nitro Mixed Fuel - 76.5% Methanol 15% synthetic 1% castor 7.5% nitro I'll stand by to see what the only other other other complications are that the rest of you can think of!Edited By Martin Harris on 17/08/2010 11:52:25 Quote Link to comment Share on other sites More sharing options...
BB Posted August 17, 2010 Author Share Posted August 17, 2010 Thanks Martin, its appears my 'general' assumption is correct. I am assumming the both mixes contain castor & Methanol. Though the degree or change in these is no more than 4% either way. So don't really factor in a genralization. BB Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted August 17, 2010 Share Posted August 17, 2010 The dodgy thing is where someone thinks that they'll just bung some nitro into some old fuel to make a "racing" brew. In simple terms, adding 1 1/2 pints of nitro to a gallon of straight 85/15 fuel to mix up some 20ish% would reduce the oil content to around 12.5% Quote Link to comment Share on other sites More sharing options...
