birdy Posted November 6, 2010 Share Posted November 6, 2010 The time has finally come to buy my futaba 6exp some new batteries to replace the original 700mah ones - they only gave half an hours of use after 7 hours charging today. So, what to get? And then question number 2 - is it ok to cycle the batteries via the side port of the tx? I was looking at the "instant" charge retaining batteries and apparently you should cycle rather than top them up, and I don't really want to have to remove the batteries from the tx to do this. Thanks, Birdy Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 6, 2010 Share Posted November 6, 2010 Not sure on the exp, but may radio's have a diode in the charging circuit for protection, but that stops you from cycling them in situ. But you don't need to cycle them every time so taking them out isn't a big issue. Quote Link to comment Share on other sites More sharing options...
Pete B Posted November 6, 2010 Share Posted November 6, 2010 I got my Optic 6 battery from here, Dusty. Good choice, quick service, cheap postage Pete Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted November 6, 2010 Share Posted November 6, 2010 I bought the Eneloop battery pack from my local shop, they are the Overlander ones. They are absolutely fantastic, they retain their charge easily. Highly recommended! I paid ?25 for the pack by the way. Quote Link to comment Share on other sites More sharing options...
Lee Damms Posted November 6, 2010 Share Posted November 6, 2010 I got fed up of my 6exa 2.4ghz transmitter batteries going flat at the field and found I could'nt use my field charger (no luck with ripmax) so onto the net and found that the protection diode could be bypassed, I fitted a 1.1amp polyfuse across the diode works a treat the diode position was identified by http://www.siriuselectronics.com/index.php?main_page=page&id=9 apparently some of the more upmarket Futaba transmitters already have these fitted. This has also been carried out on the older T6xa transmitter. sirius electronics use a 30 awg wire across the diode to act as a fuse or recommend a 2amp pico fuse. The 1.1 amp polyfuse would trip at 2 amps. 1.1 is the maximum holding current and you should never exceed 1 amp via your tx charging socket anyway. PS my tx was out of warranty when I did this and I only did it after requesting a price from Ripmax for them to do it. I'm still waiting, but then its only been since June 2009. Quote Link to comment Share on other sites More sharing options...
