IanP Posted December 5, 2010 Share Posted December 5, 2010 I have a T8FG Tx.The manual makes a point of saying that it must only be charged with the supplied charger.I have always charged my other Futaba Tx's with my field charger. Does anyone know of a reason why I shouldnt do this with the T8FG. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 5, 2010 Share Posted December 5, 2010 Hi Ian The 8 FG is my main TX these days and I rarely use the charger supplied. I tend to fast charge NiMHs (the way I believe they're happiest being treated) and simply take off the batt cover and connect up the charger to the 1700mAh NiMH. Occasionally I'll cycle the pack too. Quote Link to comment Share on other sites More sharing options...
IanP Posted December 5, 2010 Author Share Posted December 5, 2010 Hi David, This is what I thought. Is there a problem charging the batteries in the transmitter?I only charge at maximum of 500ma. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 5, 2010 Share Posted December 5, 2010 In some cases not Ian but I direct charge - 1. Because I don't have a plug lead I can hook up to my LCD screen chargers (although I'm sure I could get one so perhaps I'm lazy) 2. I'm not sure what 'protection' circuits are built in to the Tx so I charge direct just bypass these. Like me you've probably noticed how little is taken out of a TX when you re-charge after a flying session, especially dedicated 2.4GHz Tx's so I prefer not to leave them on charge overnight like in the good old days Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 5, 2010 Share Posted December 5, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Ultymate Posted December 5, 2010 Share Posted December 5, 2010 I have the Futaba 10C and fast charge regularly through the usual socket on the side of the transmitter no problems to date Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted December 6, 2010 Share Posted December 6, 2010 David, at what rate do you charge your NiMHs? My Futaba T7C 2.4GHz TX was supplied with a 9.6v 2300 NiMH battery. I usually use the supplied wall charger but a faster charge might be useful.Edited By Barrie Dav 2 on 06/12/2010 08:50:29 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 6, 2010 Share Posted December 6, 2010 Just 1C Barrie so 2.3amps in your case. Quote Link to comment Share on other sites More sharing options...
Barrie Dav 2 Posted December 6, 2010 Share Posted December 6, 2010 Thank you David. B. Quote Link to comment Share on other sites More sharing options...
