JayCee Posted December 28, 2010 Share Posted December 28, 2010 After a bit of help and advice please. Just started to assemble my Chrisie Pressie Hangar 9 Pulse 125 which is going to be Electric Flight. The model requires to four cell 5000 mah batteries in series. I have purchased a Hobbywing 70A-HV ESC it clearly states NO BEC However there is a red lead connected to the throttle output (BEC?) There is nothing in the instructions regarding removing the Red + lead so that I can install a UBEC Also there is a thin BLACK - wire, again the instructions give a complicated connection sequence to avoid a 'Spark' when the battery is connected. However as I am using two batteries in series using 'Deans' connectors it's not possible to follow their instructions:- Connect main RED + first, then THIN BLACK - then within 3 seconds Main BLACK - Just not possible using 'Deans' I don't want to use 'Bullet' type connectors as there is to much room for error when connecting the batteries in series. JC Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted December 29, 2010 Share Posted December 29, 2010 Hi Jaycee, Probably the neatest way of connecting the thin black wire is to plug it into the negative connector on the negative battery's balance connector.(The current through this wire will be low). You must make sure that you connect this wire to the negative of the two batteries to avoid a short circuit across this battery when the main black lead is connected. You'll also need to make a break in the negative arm of your main wiring harness with another Deans plug & socket connection on the main black wire. This connector will therefore be the last connection made when all is connected up. You could of course have two Deans connectors wired in here - one for the thin black wire & one for the main black wire & do away with the connection to the balance connector. The red wire in the Rx plug may well have no connection & perform no function, and is just left intact from the standard lead during manufacture. To be safe just remove the red wire from the plug to use a UBEC. I hope this makes a bit of sense - let me know how you get on as I'll be using this sort of arrangement in a future model. Another good source of info is the Giantcod forum. Cheers Richard Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted December 29, 2010 Share Posted December 29, 2010 You must make sure that you connect this wire to the negative of the two batteries This sounds a bit confusing after reading it back. Connect the thin black wire to the negative lead in the balance connector on the first series battery. Quote Link to comment Share on other sites More sharing options...
JayCee Posted December 29, 2010 Author Share Posted December 29, 2010 Thanks Richard, thought nobody loved me In the end I did this:- Made a series connector lead with Deans plugs for the battery(s) but terminating in 4mm bullet connectors to connect to the ESC. I have managed to incorporate the small black - with a 2mm bullet connector and the same on the ESC so that I can connect as per Hobbywings instruction manual. I wanted to use Deans for the batteries to try and keep everything universal. Was quite pleased with myself until I realised I had forgotten to incorporate the UBEC supply in with the + & - on the ESC.... and it looked so neat I managed to contact Hobbywing in China regarding the red wire in the throttle plug and got the reply 'The Red Lead is useless' which I assume is a literal translation meaning it's not connected to anything! JC Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted December 30, 2010 Share Posted December 30, 2010 Neatly done job JC. Hobbywing's spark killer is a good idea. Good luck with the Pulse 125. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted December 30, 2010 Share Posted December 30, 2010 Posted by JayCee on 29/12/2010 23:34:37: I managed to contact Hobbywing in China regarding the red wire in the throttle plug and got the reply 'The Red Lead is useless' which I assume is a literal translation meaning it's not connected to anything! Well maybe not, if an ESC has a BEC it uses this to supply the voltage to the microprocessor on the ESC, it will still do this if you disconnect the red wire providing the ESC has a BEC, if it doesn't have a BEC the power for the microprocessor will be from the reciever power supply. Quote Link to comment Share on other sites More sharing options...
