Paul Williams Posted January 24, 2011 Share Posted January 24, 2011 Hi all I am fitting a RCGF engine into a large scale P47. I am wondering if the ing unit will be ok fitted inside the cowel. I know this is not an ideal enviroment but there are numerous problems if I fit it behind the fiewall. It would be sited at least 2" from the exhaust. What are your thoughts please as anybody done this without problems. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted January 25, 2011 Share Posted January 25, 2011 it could well be ok but I would be concerned at the temperature inside the cowl.Its not just the exhaust gasses that are hot as about the same amount of heat is given off by the engine.It might be worth adding a small shroud & making sure cool air is ducted over it. Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted January 25, 2011 Share Posted January 25, 2011 i mounted my ignition module on the firewall of my raven just do everything you can to isolate from vibration and heat Quote Link to comment Share on other sites More sharing options...
Ultymate Posted January 25, 2011 Share Posted January 25, 2011 Don't wrap it in foam allow the air to get to it, vibration is the main enemy, sit it on a bed of foam I usually use velcro straps to secure or cable ties. If you use cable ties I recommend you put lengths of fuel tubing over them where they contact the ignition unit Quote Link to comment Share on other sites More sharing options...
Snorbitz Posted January 25, 2011 Share Posted January 25, 2011 If you have a look at these photos you'll see what i did...here.I haven't had any problems with this set up. Quote Link to comment Share on other sites More sharing options...
Paul Williams Posted January 25, 2011 Author Share Posted January 25, 2011 Thanks guys I think I will go for it there is enough room to fit a heat sheild so should be ok. Great pics very professional job. Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted January 25, 2011 Share Posted January 25, 2011 Make sure you keep it well away from the receiver, wherever you decide to put the ignition unit. Quote Link to comment Share on other sites More sharing options...
Ultymate Posted January 26, 2011 Share Posted January 26, 2011 Relative position to receiver is not an issue if you're on 2.4 gear Quote Link to comment Share on other sites More sharing options...
Paul Williams Posted January 26, 2011 Author Share Posted January 26, 2011 Thanks for the feedback guys its fitted to firewall . Quote Link to comment Share on other sites More sharing options...
