David Ashby - Moderator Posted June 26, 2012 Share Posted June 26, 2012 Hi Andrew I certainly find I need to be careful, thankfully our grass patch is ususally cut pretty well so there's nothing for the model to trip on when taxiing. Full up elevator and slow speed will indeed make it stall Quote Link to comment Share on other sites More sharing options...
Les Haley Posted June 26, 2012 Share Posted June 26, 2012 Hello, First post for me. I lost my Raven on the maiden flight to unknown problems, however Taxiing was not a problem for me at 125mm CG From LE. This is beacause I ordered Custom gear from TNT Landing Gear that was 1 1/2" longer than stock giving the Raven a more scale look as well as moving the axles forward which I believe is the key. Les Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted June 26, 2012 Share Posted June 26, 2012 Interesting Les, I had a look on their site but couldn't see anything listed under Seagull. Would you have a link please? Quote Link to comment Share on other sites More sharing options...
Les Haley Posted June 26, 2012 Share Posted June 26, 2012 David, I had them make it to my specifications. It is not a stock item that they carry. I don't think I even told them what the gear was for when I ordered it. Quote Link to comment Share on other sites More sharing options...
Les Haley Posted June 26, 2012 Share Posted June 26, 2012 BTW, The setup I used on my late Raven was a Hacker B50-9XL with a Hacker/Jeti 77 opto Esc, a 6v 2200 NiMh in the tail providing power to the servo with a Zippy Compact 6S 3700mah LiPo providing power to the motor. Up front I had a 16x10 APC Electric Prop. This setp gave me 1120 watts at 48 Amps. Not Bad.....for a rocket ship! All up weight was about 8.25 lbs. My CG was at 125mm I use Futaba FAAST gear. My maiden lasted 25 seconds. I took off at 1/2 power, made a gentle turn down wind, flew it up the field then began a gentle sweeping turn back towards the landing strip. Thats when It simply continued rolling and spiraled in to it's demise. I had enough altitude for it to make 3 spirals before dissappearing into the jungle like canopy. My TX stick movements made no difference to the models behaviour. I was unable to find the ship and after 3 different attempts I have given up on finding it until Autumn. Edited By Les Haley on 26/06/2012 20:50:13 Edited By Les Haley on 26/06/2012 20:51:29 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted June 27, 2012 Share Posted June 27, 2012 Darn, really sorry to learn about that Les. Quote Link to comment Share on other sites More sharing options...
Andrew Pirie Posted June 27, 2012 Share Posted June 27, 2012 Yeah i hold full up elevator to taxi but it still wants to dig its prop into the grass. Therefore i have to push it out to the runway, which for such a good looking plane, is not a good look! Take off roll, i have to feed the power in really slow all the way up to full power to avoid tipping. Once in the air its great. The stalling i was referring to David was not connected with slow flight then whacking in full up elevator. Hard to explain really, say your flying along good speed straight and level, then feed in full up elevator to perform a loop..the plane simply snap rolls at the top of the loop. Its not always the same direction it snaps. This is leading me to think that its stalling a tip. It will loop fine if you do a wide loop. Presumably with a harsh elevator input its bleeding off too much speed in the loop. Hope that makes sense??? Im running an Irvine 53, 11x7 prop my cog is set to 135mm aft of LE. I feel it needs a bigger engine in it so might squeeze in a 61 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted June 27, 2012 Share Posted June 27, 2012 Well I tend to fly big loops with it myself and almost never need full elevator in the process.....I think I'm probably frightened to Is it worth seeing about getting the C of G a bit further forward? Quote Link to comment Share on other sites More sharing options...
Andrew Pirie Posted June 27, 2012 Share Posted June 27, 2012 Thats exactly todays task. Do you know what your cog is? Mine is already 10mm forward of the recommended cog, as i read somewhere that the cog in the manual was too far aft Quote Link to comment Share on other sites More sharing options...
Garry Baker Posted March 28, 2013 Share Posted March 28, 2013 Hello From Ontario Canada. I am just assembling my new turbo raven. by seagull models. I am putting the new evolution 10cc gas engine in. Will be using a custom muffler by bisson mufflers here in canada. It is an upright muffler, with some modification to put the exhust pipe in the rear. It will fit inside the cowl and will exhaust out of the inderside rear opening of the plane. I believe that this plane will fly like a warbird. My weight so far seems to be at 6lbs, 10 oz with 2300mah life battery.I I will let you know how things go with this set-up. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted March 29, 2013 Share Posted March 29, 2013 Hi Garry, nice to hear from you. Good luck with that, look forward to hearing how it goes. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted March 29, 2013 Share Posted March 29, 2013 Still fancy one of these but to many models waiting to fly at present and no good weather.Except today looks a cracker.Hi Tim Quote Link to comment Share on other sites More sharing options...
Jim Davy Posted November 28, 2013 Share Posted November 28, 2013 Hi, I've just got a Turbo Raven and need some advice on suitable servos. How much pulling power (torqe) do they need for this model? I,d be grateful for any advice. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted November 29, 2013 Share Posted November 29, 2013 Hi Jim, it's no 3D'er and best flying big and smooth much like a pattern aerobat so good std size servos should be fine, perhaps sport digitals such as Spektrum 821s. Quote Link to comment Share on other sites More sharing options...
Jim Davy Posted December 1, 2013 Share Posted December 1, 2013 Thanks David, so 5 kg servos should do the job and have a bit in reserve if i read you right. Keep up the good work with the Mag.. Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 2, 2013 Share Posted December 2, 2013 You do Jim, 5kgs will be fine. Quote Link to comment Share on other sites More sharing options...
Tom Ling Posted July 31, 2016 Share Posted July 31, 2016 Hi guys Iv just brought the above model, i will be fitting an asp91 2 stroke. Would you say there is a correct CoG as I think il aim for about 130-135mm. Many thanks Tom. Quote Link to comment Share on other sites More sharing options...
Bill Foster Posted January 14, 2018 Share Posted January 14, 2018 Seagull MANUALS available here; Bill Quote Link to comment Share on other sites More sharing options...
Bill Foster Posted April 16, 2018 Share Posted April 16, 2018 **LINK** manual here... Bill Quote Link to comment Share on other sites More sharing options...
Bill Foster Posted April 16, 2018 Share Posted April 16, 2018 my build thread is here: **LINK** Bill Quote Link to comment Share on other sites More sharing options...
Julio Guilherme Nogueira Diana Posted August 26, 2018 Share Posted August 26, 2018 it is a nice flying model apart of that problem.Posted by Andrew Pirie on 27/06/2012 11:07:59 Take off roll, i have to feed the power in really slow all the way up to full power to avoid tipping. Once in the air its great. The stalling i was referring to David was not connected with slow flight then whacking in full up elevator. Hard to explain really, say your flying along good speed straight and level, then feed in full up elevator to perform a loop..the plane simply snap rolls at the top of the loop. Its not always the same direction it snaps. This is leading me to think that its stalling a tip. It will loop fine if you do a wide loop. Presumably with a harsh elevator input its bleeding off too much speed in the loop. Hope that makes sense??? Hello guys, I am having the exactly same problem with my Raven, it tip stall at the top of the loop, also she is dropping the left wingway before slow down, never saw a plane do that before, anyone had the same problem and have sorted out? Quote Link to comment Share on other sites More sharing options...
Bill Foster Posted January 24, 2020 Share Posted January 24, 2020 Hey people..Happy 2020..! Let's get the Seagull Turbo Raven thread revived...mine has not flown yet. Still a Hanger Queen! Have been contacted by a fellow owner (Arnold) who is getting ready to maiden his second Raven. Still lots of concern about that CG location. Bill Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 24, 2020 Share Posted January 24, 2020 Hi Bill, even without the manual, the C of G of many ARTF Is On or very near the wing tube. The wing tube is usually built at the thickest part of the airfoil in the middle of the aeroplane where strength is needed You have the manual which states 145 mm from Leading edge On the wing tube line Which is a really good starting point for C of G Edited By Denis Watkins on 24/01/2020 05:50:24 Quote Link to comment Share on other sites More sharing options...
Bill Foster Posted January 24, 2020 Share Posted January 24, 2020 Hi Dennis, Yes, the "spar" or wing tube is usually a good place to look at, for the CG point, however with the long nose of this Raven, flyers are relating disasters with 145mm back from LE resulting in a tail heavy model. Reviewer David Ashby uses 135mm...others go for 125mm for the maiden, and some go all the way to 110 mm from leading edge. Apparently this situation is somewhat common with this manufacturer, and has occurred with other models they have released. On another note, Seagull (the factory), had also stated this model would require a 4S lipo pack and fly with a 10/7 prop. Since the model is weighing in at 8.5 pounds, flyers are going with either 5S or 6S packs along with either 14" or 15" props and a nice round 1000 watt power system to properly fly this model. Bill Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 24, 2020 Share Posted January 24, 2020 Seagull Turbo Raven Wing span -------------------------59.8in (152cm). Wing area --------------592.1sq.in (38.2sq dm). Weight --------------------6.4 -7.1lbs (2.9-3.2kg). Length ------------------------------51.2in (130cm). Engine -------------.46 - .55 cu.in -----2-stroke. .52 - .72cu.in -----4-stroke. Radio ----------------- 4 channels with 5 servos Help, in general Most 5 foot span ARTF come out around 7lb AUW, and trainer style around 6lb How have we got to 8.5lb on this 5 foot span beautiful airframe? Edited By Denis Watkins on 24/01/2020 14:31:34 Quote Link to comment Share on other sites More sharing options...
