Steven Butler Posted June 25, 2011 Share Posted June 25, 2011 Hi allI am looking at acquiring an alpha 180 glider but it does not come with a motor etc. I have never ventured into electric flight so have no idea what I will need to complete the model. I have a fusion elysium charger so can charge lipos. Can anyone suggest a motor/esc/ battery set up and where I should go to buy. Any help gratefully receivedSteve Quote Link to comment Share on other sites More sharing options...
Pete B Posted June 25, 2011 Share Posted June 25, 2011 Have a look at this thread, Steven. Quite a bit of info there - if you have any further questions, ask away! Pete Quote Link to comment Share on other sites More sharing options...
PatMc Posted June 26, 2011 Share Posted June 26, 2011 Hi Steven, I have a Protech Unlimited 600 which uses the same fuselage & tail as the Alpha but smaller span wings. It's faster & aerobatic rather than a thermal floater, however the motor mount problems are identical & IMO the same power would suit the Alpha. I'm using one of these inrunners with 3s 2200 lipos, a 30A ESC & a Graupner 8x4.5 folding prop. This pulls around 26A for 270W so even though mine has been OK I would advise using a 35A or 40A rated ESC. Here's a couple of pics of the battery & motor mounting method I use : You will see there's a metal "strap" holding the motor to the supplied plastic fixing. Also you might notice in the first pic there's a black painted canopy/hatch which I made in fibre glass using a spring loaded catch to retain. The original canopy was a flimsy affair that was broken when I got the model & a common problem with both of these Protech models. When I obtained the model (second hand) it came with a spare fuselage & tail unit. I've fitted this out for slope soaring with a dummy spinner & the servos well forward to help get the cg right. This one has a canopy moulded from a pop bottle that's permanently taped in place.Here's a couple of pics showing the servos fixing & the model ready to fly in sloper mode. Quote Link to comment Share on other sites More sharing options...
Steven Butler Posted June 26, 2011 Author Share Posted June 26, 2011 That is a very thorough reply. Thanks for the help guysSteve Quote Link to comment Share on other sites More sharing options...
